Old 01-10-2008, 10:36 PM   #1 (permalink)
The Mighty Mira - '92 Daihatsu Mira
90 day: 61.32 mpg (US)
Video: Electric Assist Velomobile going 50mph!
Check out... someone hitting 45-50mph on the flat with electric assist! That is SO cool!
[YOUTUBE]http://www.youtube.com/v/zcxLNvkee7A[/YOUTUBE]
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
Old 01-10-2008, 10:44 PM   #2 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
That's awesome!
That thing was really hauling if it was doing that kind of speed. I doubt it really had a 1-2kw motor in it though. Maybe 1kw max, the aerodynamics would really cut back on the amount of power it takes to get up to those speeds. If a HPV can hit +60, and a human cyclist can put out 500watts in a semi-sustained effort, then I think you could easily get away with a 500watt motor and do those kind of speeds in a adequately streamlined vehicle.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 01-10-2008, 10:53 PM   #3 (permalink)
Originally Posted by AndrewJ View Post
That's awesome!
Yes, I suspect that you could easily get away with a 1kW motor in there, depending on the velomobile. With the WAW, it should take almost exactly 1kW.
e.g. 250W * (80/50)^3 = 1.02kW That's for 50mph, or 80kph.
I have the feeling that within a couple years these things are going to be EVERYWHERE.
Old 06-11-2008, 12:29 PM   #4 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
wish these things were a few hundread bucks.. id snap one up and just put a scooter motor..
I just want something that gets over 100mpg and is enclosed for bad weather
Old 06-11-2008, 01:53 PM   #5 (permalink)
Christopher Jordan's Avatar
White Whale - '03 Chrysler Town & Country mini van all white
I have seen that video with the camera glancing at the speedometer a few times. Impressive! 50 kph or 50 mph - whatever. Those noisy 2-stroke scooters get about 35 mph now. With aerodynamics that makes so much more sense than "alternate this" or "alternate that" or just more vapor-ware coming in a few years.
Old 06-11-2008, 05:49 PM   #6 (permalink)
Veggiedynamics
yeah no doubt for commuting id go electric if i could get a 70mile per day range with opportunity charging..
really if a 250 watt motor will do this add a couple hub rims to one of these and you got a killer commuter.. just need to make sure a hub rim can do 50 mph..
but still these things run in the thousands of dollars. there by no means cheap
Old 06-11-2008, 11:24 PM   #7 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I wonder how crazy I could get with a bicycle, electric motor, and aero-shell and still have it considered a bike!?
I know a lot of states have a 20 mph speed limit on electric motors on bikes.
Maybe just keep it slow when cops are looking.....
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 06-12-2008, 12:30 AM   #8 (permalink)
The Feds say anything under 1hp and up to 24mph is considered a bicycle. States vary. Here in CA the rule is 20mph. I usually keep it at 19 to 20 mph just to not draw attention. Haven't built the fairing yet.
JJ
Old 06-12-2008, 06:48 PM   #9 (permalink)
So many throttle controllers and governers now- Canada boasted 40 kpg in 2001, but CA restricts them to 20. I rarely overpower mine. The rear hub cassette was geared very very low, so I swapped my front gear to the largest and highest I could cram in there.
It is like an overdrive, 1 or 2 more mph; but down hills- my heart doesn't beat that fast
Video: sweet electric Yaris is driving! (Conversion) MetroMPG Fossil Fuel Free 1 12-15-2007 01:11 PM
Video: Yet another Electric Powered Geo Peakster Fossil Fuel Free 7 12-08-2007 07:44 AM
