11-06-2019, 05:02 AM
In the fasting lane
The Verge TS hubless in-wheel electric motorcycle
https://rmkvehicles.com/newsfeed/2019/11/5/on-the-vergenbspof-changenbspnbsptsnbsp-nbspteemu-saukkio
The more I look at it, the more my mind is blown.
The motor is in the rim. And look at how the rear fender is mounted...
I hope they have a practical solution for changing and balancing tires though. And I wonder if the exposed power cables will last and be safe enough.
 lifetime FE over 0.17 Gmeter or 0.1 Mmile.
Investors woes:
"In hindsight, I should have placed a bet on the horse that won the race"
"In hindsight, I should have bet more on that horse"
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
11-06-2019, 11:09 AM
So the motor is what we call an outrunner. Good choice for torque. Looks like 8 bolts holding the tire/ fender on, quick change connectors on the wiring. Looks like your leg protects the wires when ridden. I'm so over hubless.
The Following 3 Users Say Thank You to Piotrsko For This Useful Post:
11-12-2019, 08:58 AM
In the fasting lane
Thanks, that made me look up https://en.wikipedia.org/wiki/Outrunner.
Coils on the fixed inside, magnet ring rotating outside.
Investors woes:
11-13-2019, 10:55 AM
Ah ha! Finally a vehicle mass and speed appropriate application for a hub motor.
The exposed power cables are safe enough. The drive can shut down at the slightest hint of a ground fault or short.
11-14-2019, 09:06 AM
And the bearings styles may allow it to last longer
11-14-2019, 07:05 PM
I am unaware of any complaints about hub motors not lasting long enough in a bike application.
It's a lot more bearing surface, which is good but also that sealing edge is huge and a lot closer to all the dirt and water you don't want in there.
