The Following User Says Thank You to Cd For This Useful Post: | RobertSmalls (09-24-2009) |
Today | |
09-24-2009, 09:32 PM | #2 (permalink) |
Ultimate Fail
It looks as if the spoiler in front of the wheels has a hole in the center.
I wonder what they are suggesting about the A pillar area. Eventhough the grille area looks larger in the new 'smilee' face version, it would appear that the area hasn't changed all that much - just moved around into a new shape. |
09-24-2009, 10:05 PM | #3 (permalink) |
Left Lane Ecodriver
This video is excellent. It shows you a handful of little tweaks Mazda found, and it helps you visualize each one. Mazda is aeromodding the Mazda3.
In the shot of the A pillar, they deleted the rain channel, or more likely just made it smaller. Something I will test on the Insight. As for the hole in the front fender deflector, I have no idea why, but since it's there, I can only surmise that it was found to reduce Cd, somehow. |
09-24-2009, 10:08 PM | #4 (permalink) |
Left Lane Ecodriver
Regarding your taillights: an abrupt end to a body (i.e. a Kammback) makes good aerodynamic sense. A suddenly truncated tail outperforms a rounded one. That's why small trunk lid spoilers and Bangle Butts are used, and it's why the Chevy Volt's rear is creased.
09-24-2009, 11:12 PM | #5 (permalink) |
Ultimate Fail
Indeed ! Here is a very good video of the Volvo C-30 in the wind tunnel. Note what the fellow says at 2:50 on the video. Adding a sharp edge saves 5-6 liters of fuel a year. |
09-25-2009, 01:05 AM | #6 (permalink) |
some justification on what I wanted to do
The videos show exactly why I wanted to do CFD instead of tuft testing on my truck project. All my research showed that LITTLE STRIPS and RIDGES do make a difference worth persuing
09-25-2009, 01:56 AM | #7 (permalink) |
herp derp Apprentice
Saturn-sold - '99 saturn sc1 Team Saturn 90 day: 28.28 mpg (US) Yukon - '03 GMC Yukon Denali 90 day: 13.74 mpg (US) Thanks: 43
i am suspect that it isnt for least drag, but compromise for brake cooling. the video of the area after shows the remaining air flow moved toward the caliper/rotor instead of simply floundering around the wheel well.
09-25-2009, 02:23 AM | #8 (permalink) |
i've noticed the hole in the wheel dam on some other cars, i think the vw golf has this in some way, and i fiat minivan i seen on the road here sometimes...if i'm correct... i'd assume it's for break cooling as it seems to allow air to remain flowwing up into the arch in the video...
aer·o·dy·nam·ics: the science of passing gass *i can coast for miles and miles and miles* |
09-25-2009, 02:44 AM | #9 (permalink) |
In Lean Burn Mode
MisFit Talon - '91 Eagle Talon TSi Team Turbocharged! 90 day: 39.03 mpg (US) Warlock - '71 Chevy Camaro Fe Eclipse - '97 Mitsubishi Eclipse GS Thanks: 1,256
Cd you always find the coolest stuff!!!
It amazes me how a little sharp angle can make this much of a difference. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Aftermarket rear hatch with roof extension | Piwoslaw | EcoModding Central | 2 | 06-06-2011 04:33 PM |
Woohoo! Mazda 2 coming to Canada | MetroMPG | General Efficiency Discussion | 4 | 04-19-2010 10:36 PM |
1994 Mazda 323 hatch "My Eco Project" | Jason | EcoModding Central | 10 | 06-05-2008 01:34 PM |
ATTN: METRO SWIFT OWNERS (with NO A/C) - Rear Canvas 'Flow Thru' Hatch Cover | XFi | For Sale | 0 | 03-25-2008 06:59 PM |
