Old 06-04-2009, 05:07 PM   #61 (permalink)
jetta - '96 Volkswagen Jetta GL
90 day: 37.94 mpg (US)
Fanny - '08 Honda Fit Base
90 day: 36.19 mpg (US)
Man those gutters look great, I might have to look into that for myself
Old 06-04-2009, 09:52 PM   #62 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Thanks, ratherbehiking! I really like how they turned out, too. Not too bad for a few bucks at Lowe's. I haven't had one bit of trouble with them, either.
-Terry
Old 06-04-2009, 11:32 PM   #63 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
I'm gonna have to try that!!!!!!!!!!!!
Old 06-05-2009, 08:05 PM   #64 (permalink)
Lurking footless halls
Silveredwings's Avatar
Dark Horse - '16 Ford Mustang GT convertible Premium
Gutless Beauty - '19 Toyota Corolla SE
Originally Posted by thebrad View Post
Anyone know what kind of spider that is? I've found a few around my house and a pretty big one in the garage.
Looks like a grass spider, also known as a funnel web spider because of its funnel-shaped web.
Grass spider - Wikipedia, the free encyclopedia
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
Old 06-06-2009, 10:48 PM   #65 (permalink)
is not covered in bees.
Istas's Avatar
Honda - '05 Honda Accord EX
90 day: 27.16 mpg (US)
Insight - '00 Honda Insight w A/C
90 day: 66.55 mpg (US)
Send a message via AIM to Istas
Real slick look on the grille block, Tango. Nice fit. And that's a great idea with the gutters, I also might have to have a go at that.
Old 06-06-2009, 11:10 PM   #66 (permalink)
Deadly Efficient
Thanks, Istas!
Hey, if I can convince just one fellow ecomodder to install a grille block, then I'll consider this thread a wild success!
Currently I'm attempting to wire up a radiator fan indicator LED, but I've been flummoxed by my Vibe's TWO fan relays. Anyone have access to a wiring schematic for an '03 Vibe?
-Terry
Old 06-06-2009, 11:32 PM   #67 (permalink)
Istas's Avatar
Oh, the grille block I'll already be doing, but seeing yours is definitely motivation to make it good-looking. The gutters though, great idea on the material to use. I worry about putting holes in the metal car body down there though.
Old 06-07-2009, 09:56 AM   #68 (permalink)
Deadly Efficient
The PVC guttering idea is not original with me. That honor goes to XRinger and his thread, here.
The rocker panels on the Vibe are plastic, so I'm not worried about holes in them.
-Terry
Old 06-09-2009, 02:06 PM   #69 (permalink)
Deadly Efficient
Radiator Fan LED Indicator
I wired up a radiator fan indicator.
I popped the cover off of the fuse box under the hood and found the fan relay. Actually, there are TWO of them, and I was befuddled on which one to use. A Fluke meter and some probing gave me an idea of which leg to trap the wire under. I notched the cover so the wire wouldn't get pinched when I put it back on.
There is a row of pop-out "buttons" to the left of the steering wheel. One of them has a little coin holder, the other two are blank. I bought an LED assembly from Radio Shack. Then I drilled a hole for it in one of the blank buttons.
Then I ran the wire from the fuse box to where I had popped out the buttons. Many bad words were said to get the wire to this point.
I crimped on a ring terminal on the ground lead of the LED assembly and attached it to ground, and used a crimp connector to hook up the red power wires. Then I snapped the buttons back in the dash.
Now for that gaping hole below the bumper...
Yeah, I know I could just watch my ScanGauge to monitor coolant temperature. And I do. It runs at 181 by the thermostat. The fan comes on at 204. I'd like to block off the lower opening as much as possible, to the point it hovers around 195 on the highway. (Not much in-town driving on my commute.) The light will help me determine the smallest opening I can get away with.
-Terry
The Following User Says Thank You to Tango Charlie For This Useful Post:
j12piprius (04-12-2014)
Old 06-09-2009, 02:21 PM   #70 (permalink)
Istas's Avatar
Thanks for the mini how-to on this! I want to do this on my car, and having a pictoral how-to always helps me out with things (even if it's not the same car).
Good luck testing.
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
