EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Video: Honda Civic aero mods (https://ecomodder.com/forum/showthread.php/video-honda-civic-aero-mods-7702.html)
holypaulie 03-31-2009 08:44 PM
I've drilled in mine alloy wheels made thread inside and screwed in my aluminium discs.
Here is a video of them on youtube http://www.youtube.com/watch?v=W1dwPQ37FlA
MetroMPG 04-01-2009 08:57 PM
holypaulie - I hope you don't mind I copied your vid post (from http://ecomodder.com/forum/showthrea...eels-7405.html) into this dedicated thread. It's threadworthy on its own!
You don't have a fuel log... what kind of fuel economy are you seeing? What difference from stock?
Cd 04-01-2009 09:17 PM
Nice !!!
Please do let us know what kind of FE changes that you see !
Thanks for posting the video. I love what you have done with the car - great use of the hood vents.
Deezler 04-01-2009 10:24 PM
Pretty slick. I was definitely thinking about the front wheel well partial covers/extenders that you have on there. As long as the tire can turn, with suspension compression, they might as well be a mm away from the tire, right?
NeilBlanchard 04-02-2009 06:22 AM
Hi Paul,
I really like what you've done, too! I'm envious of the color match you have, and your fabrication skills are commendable.
I wonder how the front wheel skirts could be made from (slightly) flexible rubber/plastic?
Daox 04-02-2009 08:55 AM
I'm with the others, the mods look great. Do you have any internal ducting for the cooling system?
holypaulie 04-02-2009 11:03 AM
Not a problem.
Stock MPG City: 27 Hwy: 35
Present MPG City: 32-35 Hwy: 40-45 at 55-60 mph (hot summer 45-48 MPG)
holypaulie 04-02-2009 11:09 AM
At the full wheel turn and full suspenion there is about 4 mm clearance. I've never hit my skirt though even at the speed bump.
holypaulie 04-02-2009 11:19 AM
Here you will find more pictures of my cooling setup http://ecomodder.com/forum/showthrea...nt-6543-2.html
SVOboy 04-02-2009 01:22 PM
How do you have the rear skirts rigged up? Good stuff!
