Virtual Boattail 0n 05 Honda Civic
It's been in the mid 80's quite bit, so I've been cranking the fan in my car, with the AC off. I decided to put all that air to work and vent it out the back of my Civic LX trunk's low pressure area.
I took out the lights from above the license plate and mounted them an inch higher. That way the light still shines out, but there are two large openings. When the fan is cranked up, the air pours out of the holes. It's pretty impressive. I don't expect the have huge FE improvements, but I know it will help. I'm also aware of the danger of exhaust coming into the cabin if I don't have positive interior pressure. I'll run some tests late tonight if I can get a nap in. Again, I suspect the difference will be hard to measure. |
One Way Valve
You may be able to buy (or make) a one way valve so air goes out, but not back in. You should be able to make it work without a problem. Like you say, the results should be minuscule, but I like your thinking.
Blow on your hand as hard as you can. It's just a little weaker than that, but with more volume because of the size of the holes - each about the size of a half dollar coin. |
Let A equal 1, which is at least order of magnitude for a passenger car. The diameter of a half dollar coin is, um, 5 cm(?), which is .05m. Area of each coin is pi * .05 * .05 / 4 ~= (3 * 2.5 / 4) *10^4 ~= .0002 m^2. You have two such holes, so .0004 m^2. See where this is going? To completely negate the drag pressure the outgoing pressure would have to 10000/4 = 2500 inches of H20. Assume your car fan is really powerful and you have 10 inches of H20 pressure difference (this is pretty doubtful), at most you negate 1/250th of the drag. |
Detector?
So here are your first two questions, which I answered before you asked them: 1. What keeps the fumes out? 2. Will it make a measureable difference? Yes, it will keep the fumes out (see first post). You would have to keep the fan on. And yes, it can be measured, but I probably won't get enough samples to capture the difference (see first post), so it won't be measurable thereby. Logic tells us that it will make a difference. A lot of small differences can make a big difference. |
I'm surprised that modern cars and trucks don't have a CO detector by now... :(;)
Anyone wanna loan me their parakeet?
