07-11-2011, 03:41 PM
needs more cowbell
http://ecomodder.com/forum/showthrea...tml#post227421
Random lumps attached to your vehicle are not likely to have any positive effect. Vortex generators used on airplanes cause more drag but allow more effective control surfaces. Vortex generators on cars seem to cause more drag, and they don't have control surfaces.
07-11-2011, 05:06 PM
Yes, it will keep burglars and cats from climbing on your car.
07-12-2011, 05:00 AM
Aero Deshi
Mo, the only thing you can do to improve your aero here is to make your car longer in the back. It already is a very aerodynamic shape, it is just very short. Doing anything aero in the back part of your car, other than building a plan taper rear extension, will in all likelihood hurt your mileage, or waste your time, money & effort.
The Following User Says Thank You to ChazInMT For This Useful Post:
07-12-2011, 12:09 PM
DieselMiser
MoMoris,
The airtabs inventor actually tested them in a wind tunnel on a hatchback. He showed a 4% reduction in drag. This however was done by a professional and not an amateur.
they have some of the results in a pdf but no photos of the placement http://www.airtab.com/MicrosoftWordHondaWTReportV6.pdf
They can work. You may need a wind tunnel to get it right however.
07-12-2011, 12:21 PM
needs more cowbell
This thread inspired me to dredge up another concept, I see these were only tested on the sides, and would like to have an understanding of why rounded sides are everywhere when perhaps a sharp transition would be better. If the sides should be sharp for best aero (once the efficiency/handling compromises are understood) then that would seem a less complicated mod or one more likely to give results. A clear strip of plexiglass glued to the rear sides might suffice. Mini-boattail
But we don't know for sure if these specially designed VG would help on the top, the author speculates there.
http://ecomodder.com/forum/showthrea...-te-18133.html
07-12-2011, 03:51 PM
So far, nobody on here has been able to get better fuel economy with vortex generators.
They do help to smooth the airflow, but seem to also introduce extra drag canceling out their positive effect.
07-12-2011, 06:15 PM
#9 (permalink)
Hucho
dcb,if you can snag a copy of Hucho's book ( any ) you'll find a very lengthy discussion on edge radii.And I think you'll find that it's not a 1-size-fits -all sort of technology, when comparing squareback,notchback,and fastback bodies.
07-12-2011, 06:40 PM
#10 (permalink)
DGC - '08 Dodge Grand Caravan SXT 90 day: 17.39 mpg (US) Buick - '01 Buick LeSabre Limited 90 day: 18.52 mpg (US)
This thread inspired me to dredge up another concept, I see these were only tested on the sides, and would like to have an understanding of why rounded sides are everywhere when perhaps a sharp transition would be better...[/url]
Mainly because its the look the public has been going for. You have to remember that most people, however simple minded they may be, buy cars based on how they like they look first and foremost and car manufacturers are well aware of this. Plus, if it "looks" aerodynamic to the untrained plebeian eye, they assume it is. Most people assume smooth curves = aerodynamic when we here know this to not necessarily always be the case. Curves are good and have their places - just not everywhere. (I can think of several places I really like curves....hahaha....but I digress.)
The Following User Says Thank You to pnambic For This Useful Post:
