VSS Dilemma
I'm beginning work on my Guino install and need some input. The most accessible/guaranteed to work part of my VSS is directly off the transmission, where there are "high" and "low" outputs from the VSS. That would be easy to tap, but would these work with the guino, or would they each read funny? And the other option is to tap after the PCM which is the usual way, but my Car's speed sensor system is troubled (speedo does not work) and the problem is probably a connection somewhere in the system..so thats the last resort. I've read up on this stuff but would like some confirmation before I continue. Thanks for any input!
