WAI commentary
Had breakfast with an older gent who specializes in the science and technology of combustion and currently builds alternative fuel power plants in places like China, the US, and Canada. I asked him about the WAI and whether he thought it would work, and if so how. He says that the heat-expanded air would cause, in effect a richer mixture, though no extra fuel unless the rate of inject were separately adjusted. The WAI certainly does not produce a leaner burn (many of you probably already know that). Any FE gains he thought would have to be produced by heat energy recovery in the hot air being re-introduced to the engine from the manifold. He thought the gains would be minimal (which is true, by my test anyway). But adjusting the flow of fuel would create further gains. Has anyone done that in addition to the WAI itself?
The fuel ratio is kept at stoichiometric by the O2 sensor. It can't run richer without the O2 sensor seeing this and correcting for it.
Yeah, I think pretty much anything since the late 80s / early 90s has an O2 sensor.
So this means then that the WAI does in fact create a leaner burn by manipulating the way the O2 sensor balances the fuel/air mixture... perhaps heat recapture is relevant, but the mixture would be more relevant, it seems to me.
Nope, it keeps the ratio at stoichiometric. The result is lower power output for a given throttle opening. To maintain speed, you must therefore open the throttle further. This decreases pumping losses which increases efficiency. Also the warmer air promotes a faster burn I believe, which leads to higher peak cylinder pressure and additional torque.
I'm not sure how it would. If anything, running too hot will cause preignition and pinging and the knock sensor will see that and retard timing.
California98Civic -
I tried to find a really good definition, but this is the best I could find : Understanding air density and its effects Quote:
Air - Temperature, Pressure and Density And came up with this : http://ecomodder.com/forum/member-cf...oolbox-com.jpg When I say pseudo-AFR I think I am being misleading. Maybe a better way of saying it is that you are reducing the *displacement* of the engine by the percentage in the 4th column. The AFR stays the same from the 02 sensor POV. It's just that less oxygen and therefore less fuel is being burned per volume of air. If what I am saying is correct, then this would give you an idea of the possible "change" in engine displacement at different intake temperatures : http://ecomodder.com/forum/member-cf...oolbox-com.jpg BTW - I am not a car-guy either, so my statements are subject to correction by others. CarloSW2 |
