Warm Ram Air Intake?
Howdy all!
BACKGROUND I've just spent the last few days reading a kabillion threads, articles, and papers on Air Intakes (AI): CAIs, WAIs, Ram Air Intakes (RAI), superchargers, turbochargers, and the like. Several of those were here from ecomodder. What I found was a miasma of special cases where one type of intake would give better HP / FE in one regime, but could have the opposite effect in another. So I tried to distill down the things we can definitively say: 1) Reducing pumping loss through the engine improves fuel economy. Viewing the engine as a big air pump, that has the immediate corollary 2) Increasing AI pressure could improve fuel economy under certain conditions, such as WOT on a fuel injected vehicle, vehicles with carburetors, turbos, etc. But under low load with fuel injection, the higher pressure is wasted, because the throttle just restricts to keep stoichiometric. The essential problem is that, while a crapton of modifications make the oxygen at the AI more dense (cold, pressure), that delivers more power, not necessarily better fuel economy. It helps pulse and gliders, but does little for someone like me who sets the cruise control. I'm currently designing the front to Champrius 4.0 and a big part of that is how to properly route the radiator outlet flow. The stock design is to dump a huge portion right under the engine, and about 40 sq in through the cat channel. I'm going to enclose the entire engine bay as best I can, but am still concerned about air near the top of the radiator having to take several twists and turns to exit through a rough compartment. My bright? idea was to put an (Warm Ram Air Intake) WRAI behind the radiator near the top and connect it to the stock air box. Even if this does nothing for the engine itself, I believe it will give me minor gains just providing suction near the top of the radiator. More specifically, it will make the radiator more efficient enabling a smaller air inlet, and it will reduce outlet flow across a rough engine bay. This is maybe 0.5% stuff, but it's low hanging fruit since I'll be modding that whole area anyway. Champrius is a 2009 Toyota Prius with normal coolant temperatures 185-190F and stock air intake around 5-10F above ambient. The inlet duct is located on the passenger side above the wheel, which goes through a resonator, then a hose, and into the air box. I've already done tests where using engine bay air directly makes FE worse by around 2%, even though the temp was +5F higher. The only explanation I had at the time was that the higher air pressure near the front of the wheel was significant (I didn't know about RAIs back then), or that my margin of error was larger on those runs for some reason. QUESTIONS Would the WRAI described above (behind the radiator) be better than the stock intake for FE at 65 mph cruise control? That question really boils down to: Does anyone know the difference in pressures at the wheel well top vs. behind the radiator? (Julian Edgar, where are you when we need you? ;) I know the MAF measures mass air flow and temperature, so this could be the same as... Does the car measure AI pressure? If so, I could just mock up what I'm thinking and measure all the stats directly. Can anyone think of issues with doing the WRAI? Right off the bat, it seems to me that we'd be trapping heat in a loop, which should help with cold starts / weather BUT might be dangerous in a heavy load / hot day scenario. Subtleties like ignition timing etc. need to change with the air characteristics, but I'm assuming the fuel injected ECU magically takes care of all that. And for the bonus question: has anyone already built and measured such a device? I came across a ton of DIY mods for CRAIs (Cold Ram Air Intakes) but couldn't find any WRAIs. Apologies in advance for ye readers that have already seen variants of AI questions a dozen times. If this is a standard question that I simply haven't found yet, please direct me to the appropriate sources and I'll do more research myself. Thanks! :) |
I doubt you're going to get the ram air effect behind the radiator. Maybe in front of it. But then, you won't get the heating.
That said, the only way to know for sure is to try it. |
1 Attachment(s)
https://ecomodder.com/forum/attachme...1&d=1656880943 This map shows that the Prius' engine is most efficient when operated between 2000-4000 rpm. If you're already in this range on while cruising you're not going to get a ton better. Hotter air should theoretically move the sweet spot on the map to lower rpms if that is what you want while colder air should move it to higher rpms. Ignition timing is pulled at higher rpms on most engines to protect it. This is all done automatically via the ECU. I'm not sure if that is the case on the Prius' engine because of its atkinson-ish cycle it uses. Its likely the intake charge never really gets hot enough to require this, which would be another perk of the design albeit at the expense of maximum power output. Quote:
I tend to agree with the above. Like he said, the 2nd gen Prius uses mass airflow rather than speed-density. I also doubt ramming air into the intake will do anything for fuel economy. It could potentially help with power at high speed / full throttle. But if you're trying to hypermile at WOT, you're doing something wrong. :p
Personally, I would not want to modify the drivetrain in the Prius because of how it's configured. There is a balance of power, so to speak, between the gas engine and the electric motor. If you upset that balance with engine mods, it could have unforeseen consequences. Actually, that could explain why you lost fuel economy with a hot air intake. The reduced power of the gas engine probably reduced the overall efficiency of the hybrid system. Anyway, it seems like your main goal is to find somewhere to send the hot air exiting the radiator. How about a hood vent? I'm not talking about a louvered race car hood, but rather a smallish vent placed strategically in a low-pressure zone. IIRC the best place to put a vent is right behind that sharp curve at the front of the hood. |
It turns out that while there is a bunch of pressure loss on the fluids inside the radiator, the loss on airflow is much smaller: https://www.researchgate.net/figure/...fig3_286352432 If I want to increase pressure, I can always play games with the cross section of the intake. However, I don't even know if that's what I should be doing. I had a chat with an automotive friend of mine that suggested that I don't want to be increasing air pressure but decreasing it (to get better fuel economy). In his view, if we don't have direct control over the fuel injection (say via altering fuel maps), everything boils down to how much oxygen enters the piston chambers. Cold, high pressure air has more oxygen per unit volume, while warm, low pressure air has less. So he said the only conceivable way to get better fuel economy is rarified air at WOT; otherwise, the ECU will simply adjust the throttle to ignore all the modifications upstream. That view jibes with what I've read about the Prius' air intake. It's ludicrously restrictive, far more than is necessary to simply filter air. Both the resonator and airbox cause significant pressure drops... which seems like what's it's trying to do is decrease pressure. But then that makes the placement (in a high pressure zone near the wheels) somewhat puzzling. It seems they are gathering high pressure air just so they can make it low pressure air. Maybe if they put it in a low pressure zone it would cause too much pumping loss on the engine? Man, I understood the model of the engine as an air pump, and why turbochargers were so brilliant. But this stoichiometry stuff makes my head hurt. :confused: |
Decision made... procrastinate! :)
https://www.researchgate.net/figure/...fig1_309416293 In a free flow wheel, the highest pressure zone is near the top while the lowest is near the bottom (right behind the surface contact). As we cowl the wheel more (with wells, skirts, etc.) the highest pressure zone migrates toward the front of the wheel (right in front of surface contact). Basically, the friction of the wheel is "lifting" air from behind the wheel and slinging it around to the front in the direction of rotation. From an airflow perspective, the wheels are the dirtiest part of the car. Not only does the rotation of the wheels directly induce vortices, but the top of the wheel is traveling twice the cruising speed against the airflow. It's a big fat mess that only gets worse the faster we go. Quote:
By the way, something else that I looked into was trying to change the fuel map somehow, either by getting a performance chip or fooling the ECU somehow. That was to see whether I could make the car going into lean burn. It turns out... Toyota already uses lean burn a lot, just not at cruising. When the load falls below a certain threshhold (say a slight incline), the engine will typically measure 16:1. Then at no load (coasting down an incline), the engine revs at 900-1000ish and goes into an 18.1:1 burn mode. Then at even less load, the engine shuts off and it uses electricity. I've also noticed that the car only gets less than 1/5th the aero gain uphill. So when version 3.0 was fully aeroed and got 50%+ mpg, I would get less than a +10% increase going up a serious hill. The lion's share of the gain was going down inclines, and in particular, how quickly it would move between the three regimes above. |
https://www.instagram.com/p/CewAQ08LN2l/ And my main concern was less about exhaust and more about utilizing the top end of the radiator. Once I get done with plastering over the underside of the engine, there will be a 40 sq in exit through the cat channel and two 20 sq in exits near the rear of each wheel (in the low pressure zone). Since I'm targetting a 50 sq in-ish inlet, that's more than enough exhaust venting. The problem in my mind (which may or may not exist in reality) is that it seems like the airflow will favor the bottom half of the radiator, as the path of least resistance. It also seems like the Toyota engineers felt the same way. The main radiator intake is below the impact bar at the bottom of the radiator, but they deliberately put a small intake above the bar at the top. I assume that's to get airflow saturation near the top. Since I plan on ducting the inlet, I thought that suction near the top would help airflow move that way, and be more efficient use of the radiator. It looks like I'll just have to do some asymmetric aero on the inlet duct to achieve the same effect. While is a shame... I do so love symmetry. :p |
Just out of curiosity, were you testing no insulation vs stock insulation? Or stock vs extra insulation? Or some other configuration? |
Here's another post about putting the extra insulation in: https://www.instagram.com/p/Ceym7-lrTVx/ and a how-to I whipped up especially for this site: https://ecomodder.com/forum/showthre...tml#post669246 Enjoy! |
a couple of values
These are from the 2013 Volkswagen Jetta Hybrid land speed record at Bonneville:
* Local barometric pressure, 25.90" Hg, 12.7249 psi. * Ram-air pressure @ 70-mph = 0.075 psi ( 517.4 (Pa) ) * Ram-air pressure @ 187.6-mph = 0.575 psi ( 3,963.9 (Pa) ) |
All this talk of ram air makes me wonder if the opposite isn't true at the other end..?
ie: Where's the lowest pressure area at the rear of a car? And why doesn't the exhaust exhaust there..?? Yes it's all about keeping CO low, rather than smothering fellow motorists, but perhaps one of those exhaust valves can be made to work at higher speeds where it will be useful. Hmm... you'd likely want the exhaust sealed where it goes through the rear panel. Not so easy..? |
Ye! Except they exit where the number plate is currently. (I'm guessing that's the lowest pressure area on a Bug?) (I'd love to hear that thing run! :) ) |
Strange that it would though, unless the trunk didn't seal properly and there was a negative pressure in the cabin..? Aerodynamics can do strange things, I know. Cabin vents are usually situated somewhere high up behind the rear windows aren't they? |
lowest pressure
Exhausting to the rear requires that zero leakage occur at the trunklid (boot) seal, and seal between trunk and rear seat/cabin. It's the reason NASCAR demands side pipes to dilute tailpipe gases which could be inhaled during 'drafting.' |
https://ecomodder.com/forum/attachme...1&d=1660250167 Seems to work well. Someday I will put on a slip on tail pipe and extend it past the bumper and do a A B A comparison in gas mileage. |
duckduckgo.com/?q=Bellflower+pipes
Straight outa Bellflower, CA. The H.A.M.B. can't let go of the pic, but check out www.jalopyjournal.com/forum/threads/bellflower-exhaust.400550/#post-5244862 and especially www.jalopyjournal.com/forum/threads/bellflower-exhaust.400550/#post-5537826 |
added photo- Low pressure exhaust exit
1 Attachment(s)
don't know why my photo did not show in my reply post above, but here it is again
https://ecomodder.com/forum/attachme...1&d=1660257283 |
Someone on here pit a heater core inside their air cleaner box for consistent temperatures.
I'm aware of the venturi effect aerohead and that fast moving air generally means lower pressure. But aerodynamics is a counterintuitive business and i'm confused. Here's the intuitive idea: https://robrobinette.com/images/S200...oiler_Drag.jpg And here's flow which goes with what you said: https://robrobinette.com/images/S200...ion_NASCAR.jpg And here's a pressure view from underneath a car where one can see a hint of orange high pressure behind the car: https://robrobinette.com/images/S200...d_Pressure.png (Is the high pressure just low down..?) Here's the exhaust next to the number plate on an early Lotus Europa: (my project car if I ever get the damn Anglia sold) http://www.carpictureworld.com/lotus...r-1200x800.jpg But it was moved to the more conventional spot in later models. At a guess I'd say the rear number plate area is likely to be the most consistent low pressure area on a car at various speeds if you don't care about CO poisoning..? Link to article where the pics come from: (properly placed bonnet vent seems like a good idea) https://robrobinette.com/S2000Aerodynamics.htm Other links showing the low pressure area behind a car, where people like to put boat tails to 'fill that vacuum' (your canopy included! :) ): https://www.researchgate.net/figure/...fig2_322640200 Car Aerodynamics Basics, How-To & Design Tips ~ FREE! |
pressure
2) the lowest ( but not exhaust-related region ) pressure will be just ahead of the windshield header ( Cp - 0.69 on Model 3). 3) the next lowest area will be under the car at the diffuser ( Cp- 0.37 ). 4) The base pressure of the wake will be at a higher pressure ( Cp -0.16 ). 5) The 'template' has positive pressure at its rear, all around. ------------------------------------------------------------------------------------ The rear spoiler probably allowed re-attached flow to the boot, killed separated flow upstream at a much lower pressure, allowing the attached flow to decelerate before separating at the 'new' rear of the spoiler, increasing base pressure, lowering pressure drag, and total drag. Yes, there's 'low pressure' in the wake, but it's at a higher relative pressure than elsewhere. It's why the aft-body is the most crucial part as far as drag goes. |
BUT: One does want somewhere to start your investigations before you go as far as designing and building an exhaust system. You haven't dashed out with and angle grinder, welder, bender, some pipe and a pressure meter have you..? |
Lotus Europa
This will be an interesting project when you get to it.
It's one car that put the 'body' where most place a rear spoiler. Wolf Heinrich Hucho had mentioned in his 2nd-Edition book that, adding a rear spoiler affected drag and lift almost as good as just designing the aft-body to the same 'height.' If it was Frank Costin who did the design, I applaud him. At Cd 0.29, the Europa was probably a benchmark for low drag in 1968, when it debuted. It just so happens to intersect the span of the 'slow,' 2.5:1 streamline body of revolution-derived half-body contour I used for the 2007 AST-I. I got to drive a spyder version at a party in 1969. It remains my favorite sports car. A real slot-car! Elegant. Visceral. No girly-man creature comforts. Just legs-straight-out, buns-on-the-floor, unadulterated performance! And driven 'conservatively', no doubt, very efficient, naked, off the boat from England.:) |
Aero and 649kg. But some room for improvement left. The challenge is making changes that are easily reversible so that reverting back to original is easy. Then I want to keep the "legs-straight-out, buns-on-the-floor, unadulterated performance!" too! :) I think perhaps a new thread as I/we're hijacking poor Talos' thread way off course. |
So feel free to hijack away! :D |
Talos have you tried header air for keeping warm in the winter? I really don't believe in EGR or warm air having more of a benefit over keeping a prius warmer so it can run like a normal corolla would without having to have the engine on 24/7 like a corolla would.
I think manufacturers dyno their cars at 77F so I usually just aim for around this temp for winter air for my car. If you go too crazy I wouldn't want to deal with the horsepower loss. Also, WAI for me is just helpful for around town. The car does fine at steady state, but that can be a very small percentage of my driving a lot of the time. |
Lessons learned
Unfortunately, from an engineering standpoint, it's crap. What I didn't know at the time was that exhaust fumes contain a crapton of water vapor (I later realized from the combustion, duh). That water pooled in the pipe where it bent upward, corroded it, busted it, and then filled the rear tail with hot gas. Which was of course as airtight as I could make it. Oh, but it gets better. I actually discovered this pretty early, and if I were at home I could have fixed things promptly. But I found this out while on a trip in Alaska. So I was 400 miles from nowhere and 2800 miles from home. While I limped home the exhaust melted my rear bumper, cracked all the plastic on the tail, fused all the wiring, and destroyed all the electronics. And that was *after* I cut open half the tail to let the fumes out. :eek: I have since discovered that regulations clearly state that the exhaust pipe needs to be at least level with the ground, and they recommend having a 30 degree down kink with a slight grade downward afterward. So the only way to get the exhaust to come out mid-level on the car would be to raise the entire muffler assembly. That would almost certainly impact performance worse that the gains of having the exhaust in a better spot. |
I think ram air is over rated. I once calculated how fast I'd have to go to make up for the thinner air at my high altitude. I figured out I'd have to go about 400mph to make it work! I believe I calculated that at 12,000ft above sea level. No wonder airplanes ususally use turbochargers or superchargers to make up for lost air density instead of ram air intakes.
Other than faster engine warmup WAI are a waste of time for fuel savings. They just increase energy lost to the cooling system and increase polution.
Ram air on a gasoline engine are of no use for fuel savings. They can provide a small bump in power though. On a diesel they will provide a benefit in both power and performance. At sealevel 70 degrees F and 70mph you can get a theoretical maximum of 0.09 psi of boost. Ram Air Calculator |
