Go Back   EcoModder Forum > AltModding > Saving@Home
Old 04-21-2008, 11:52 PM   #1 (permalink)
saving on computer NRG
untested by me but thrown in for discussion:
snip (unknown internet source)
... a neat utility called RM Clock can be used to undervolt the processor (Intel ior AMD). If you are a geek, it should be clear to you that this reduces power consumption and hence minimizes heating; if you are not a geek, or at least a semi-geek, don't try it - the utility has no user manual and you have to use some common sense and browse through their forum to get an idea how to set it up and running... A search in google using the "RM Clock" search string should bring it up.
BTW, this utility might be also of use for Intel/AMD based notebooks including CoreDuo. I personally use it on my Pentium M and I am pretty satisfied with the power savings it provides
un-snip
cheers
al
Old 04-23-2008, 09:19 AM   #2 (permalink)
Green Rodder
Grease Beast - '92 Dodge D250 Standard
Econo-Beater DX - '92 Toyota Corolla DX
Many performance motherboards offer voltage adjustments. I never checked to see if they could be lowered since I always needed as much voltage as they could throw at me.
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Saving power by changing computing habits and hardware NoCO2 Saving@Home 34 02-26-2008 07:23 PM
Metro computer swap? daedalusdd DIY / How-to 4 02-18-2008 06:45 PM
Saving a few watts - a few ideas that I use around the house Lazarus Saving@Home 10 02-01-2008 07:13 PM
