Old 12-22-2008, 10:54 AM   #1 (permalink)
EcoPikey Modder
big_dave's Avatar
Kunnt 1 - '04 Smart ForTwo Custom
Burner - '09 Kia Soul Burner
Send a message via MSN to big_dave
Thumbs up Weight Reduction
My first proper thread. This weekend I have a 740 mile round trip to do. So recently I have been looking to see what I can do to improve my FE. I've done the upper grill block and blocked off my inter cooler. This has seen the air intake temperature go from about 10oC to 20-30oC. MPG has improved slightly on the short runs I have done so far. This afternoon I decided to remove the rear seats, my sub and all the boot junk. The sub easily weighs 15kg and the other junk must be good for a couple of kilos. But the back seats, I just weighed them. 28kg! Yes, twenty eight kilogrammes. Hopefully that will get me much improved MPG on the run.
So thanks to everyone for all the fabulous information on this site.
Old 12-22-2008, 11:08 AM   #2 (permalink)
Dave, I wish you lots of luck with your trip, but doubt that the weight reduction will help too much on highway trip. (It will help some.) Weight is a big factor in acceleration/deceleration, but your aero and intake mods will mean a lot more to increased FE on your long trip.
Old 12-23-2008, 11:59 AM   #3 (permalink)
EcoPikey Modder
big_dave's Avatar
Unfortunately a lot of the trip will be up and down hills so was hoping the weight reduction would help on the climb. I taped up the bonnet seams today as well. Every little helps.
Old 12-24-2008, 09:28 AM   #4 (permalink)
dichotomous's Avatar
CivySi - '03 honda civic SI
90 day: 31.99 mpg (US)
reducing your waistline will help with that too, though some more than others. kudos if it wouldnt help you too much. I could easily go from 114kg to 100kg and still be healthy, that would help a lot, especially on my bike
Old 12-24-2008, 12:24 PM   #5 (permalink)
Don't forget to check the tire pressure before starting out.
Weight Reduction AnDoireman EcoModding Central 25 08-14-2022 02:24 PM
Nissan and Toyota's New Year's resolutions: LOSE WEIGHT MetroMPG General Efficiency Discussion 18 01-16-2015 04:57 AM
Weight reduction saunders1313 EcoModding Central 21 10-14-2008 11:34 AM
CRX vtec weight reduction !? chipX EcoModding Central 24 09-05-2008 08:17 AM
Very thorough article on weight reduction rsx2002 EcoModding Central 11 07-09-2008 11:53 PM
