Old 09-17-2013, 06:30 PM   #11 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
A laptop AC adapter or similar will run on high voltage DC provided that the rectifier bridge is up to the task of dealing with 100% duty cycle on half the diodes, the input voltage is within specification (144vdc should work on a power brick that can handle 110-220vac,) and that it is a SMPS. A SMPS will actually convert AC to DC before converting it to a lower voltage. A traditional transformer based supply needs AC or rapidly pulsed DC current to work, DC off of a battery will not power it.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
