Old 11-12-2010, 03:59 PM   #11 (permalink)
PSmodder lurker
Would lean towards smaller panels. The WRC racers have ablative underbody flex panels to reduce sand, dirt, water and small projectiles and protect brake lines. Large hits violently separate those panels but are easily replaced at the next repair stage. Have the same kind of mindset for your use, under car maintenance service is a lot more convenient.
Old 11-12-2010, 04:34 PM   #12 (permalink)
Aveo - '08 Chevolet Aveo LS
where do you go to get alluminum sheets?
Old 11-12-2010, 06:08 PM   #13 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
UHMW...
Old 11-12-2010, 06:09 PM   #14 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Most metal supply stores will have them. What size and gauge are you looking fer?
http://www.onlinemetalstore.com/
Old 11-14-2010, 12:07 PM   #15 (permalink)
Thinking out of the box works a lot for me.
old...
Old 11-14-2010, 01:01 PM   #16 (permalink)
...beats walking...
old...
..."tried & true" vs. "new & improved"? me too!
...I prefer things designed to "...last..." over things designed for "...planned obsolescence..."
Old 11-15-2010, 05:38 AM   #17 (permalink)
Originally Posted by SlideWRX View Post
I've been pondering using UHMW in sheets. Rally racers use 1/4 inch think stuff to protect the underbody. I think the 1/8 inch would be plenty for normal use, and even thinner might work. It is expensive compared to 'free' coroplast though; I've found online ~$120 for a 4ft x 10ft piece.
ultra high modulus is overkill $$ for our use, HDPE is inexpensive and will work fine
Old 03-07-2012, 06:30 PM   #18 (permalink)
heading for 40
redorchestra's Avatar
Hong Kong MTR - '98 Bombardier/ nee Adtranz A-Stock 5 paired doors
90 day: 102.63 mpg (US)
resurrecting a dead thread
sorry to dig this out but I am wondering if anyone has tried a fabric belly pan.
I thought heat proof fabric for oven mitts would be a good fabric for it . Therma-Flec Heat Resistant Fabric - Silver
elasticed to the front bumper above a chin pan, stretched back and hooked to the rear of the car stretched to the rocker panels and attached with screw- in -snaps.
it might also need something, perhaps electrical conduit running lengthwise for some extra stability. maybe a pipe pocket sewn into the fabric or more screw in snaps.
I often wonder if you remove your belly pans before going to the mechanic or maybe you don't use mechanics, or I wonder what they say when they see a belly pan.
Old 03-11-2012, 10:53 PM   #19 (permalink)
I have used 1 inch hex steel mesh between layers of 5 mil tarp plastic (used to cover stacks of plywood) bonded together with contact cement.
Old 03-13-2012, 04:31 PM   #20 (permalink)
heading for 40
I am thinking about trying some canvas painted with high temperature silicone on both sides, stretched between two ratchet straps running from the frame in the engine compartment to the frame near the rear bumper. it will be pulled and hooked tight to the rocker panels behind the front wheels and in front of the rear wheels.
does my sig work now?
powered trailer idea (EV pusher trailer to make conventional car a hybrid) Tango Charlie Hybrids 83 09-07-2020 12:48 PM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Electric Honda - Business Idea??? hypermiler01 Fossil Fuel Free 22 11-01-2010 09:47 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Stupid Idea 5336 and counting.... justpassntime Aerodynamics 13 09-27-2008 01:42 AM
