Went from 23 to 28 mpg.
Since Ive owned my suzuki sidekick I get if I am really careful 30 mpg, but on average 23 mpg. I assumed it was part my driving style, 3 size larger tires and 20 psi inflation.
I changed all the gear boxes to synthetic mobile 1 oil, engine to a 5w20 volvine synthetic blend and replaced all the brake parts. Had a frozen cylinder up front. I also went from the auto locking hubs to manual lockers, new speakers and wires. I dont think that did anything, but it was also done. :D Takes less throttle to go and coasts further. 0-60 seems about the same and I do not FAS. Biggest improvement is I can enter 5th gear at 30 mph and accelerate. Before I had to go almost 45 before entering 5th and if I slowed to 40 had to drop back to 4th to accelerate. |
Nearly a 18% improvement. :thumbup: Now add drag reduction clips to the disc brakes and have the alignment checked. > |
Nice job.
Curious if you have a theory on where the gain was made? Like do you think it was all the locked caliper? Or the new hubs that you are now sure are free wheeling? 18% improvement from new oil would be pretty amazing lol.
Either way, great job putting some maintenance towards better MPG! |
Well, to tell you the truth I wrote off the mpg due to having the tires inflated to 20 psi. I had heard the change from auto to manual locking hubs helps for 2 mpg and I had problems with one sticking and not slipping.
I kind of knew one of the brakes was sticking up front, but I usually engine brake. The engine Ive always used regular oil, but the synthetic mix had a toy car and was 15 bucks for 5 qts, so I couldnt resist. I also no longer have a few drops of oil where I park like before. :thumbup: My mod for a softer ride was to go to 8 inch wide rims from the stock 6 ones. I found arca racing rims are about the same weight, but made of steel. About 25 lbs is the weight of the alloys. Regular dot approved steelies are like 50 lbs a piece. :eek: I am running p235/75r15 yoko touring S tires vs the typical off road mud or swamper tires. |
post a picture please!
2 Attachment(s)
Post a photo of my vehicle? As you can see I removed a lot of stuff, lowered it and blocked the grill. :eek:
http://ecomodder.com/forum/attachmen...1&d=1421112123 http://ecomodder.com/forum/attachmen...1&d=1421112123 |
Yeah buddy, Looks nice! I like the big tires without being mud tires! perfect fit too!
Any other aero besides the grille?
I've always kind of liked the Sidekick/Tracker twins. My son isn't a big person and doesn't like big cars, I've thought that an earlier two-door model might suit him, get him above the traffic so he can see while still being a halfway thrifty ride. |
Looks like a MB G-wagon with the black paint and tint :)
