EcoModder.com
-   -   What diameter tires are you using at the moment? (https://ecomodder.com/forum/showthread.php/what-diameter-tires-you-using-moment-18783.html)
Vekke 09-11-2011 04:14 PM
I need some back up data on ecomodders tires when I will go to nokiantyres to talk about some special purpose tires which I will need on my Lupo 3L. I suggest that they would make about 5 different sizes with about 8% diameter steps :/.
You can legally change the diameter of tire 5% to each direction in EU, is it the same in the states?
Oh and the new very low rolling resistance nokian tire is not yet on the market ;).
BHarvey 09-11-2011 04:23 PM
25.5"
99LeCouch 09-11-2011 04:26 PM
25" or so, the ones the came on the car OEM. 215/55-17.
SentraSE-R 09-11-2011 05:17 PM
25.07" (P205/50-R17). OEM were P185/60-R15, 23.7" diameter. New tires are 5.31% taller. US mfrs don't recommend going above 3% taller.
gone-ot 09-11-2011 05:35 PM
...OEM on our 2011 Cruze LTZ is P225/45R18 on "flangeless" alloy rims.
cfg83 09-11-2011 05:39 PM
Vekke -
195/65 15, one size up from stock, about 2+% larger diameter and 1 lb heavier than stock. I don't know of a specific law in the USA that prohibits tire size change. It's more a physical thing of fitting in the wheelwell. I could have fit two-sizes up from stock for a 4% larger diameter, but the tire jumped to 3+ lbs heavier.
CarloSW2
oil pan 4 09-11-2011 06:20 PM
In the US we can do pretty much what ever we want with tire size as long as it with in reason.
On my car I run P225/60R16.
Taller and narrower that the dead (245/45) 16 inch OEM size my car came with.
On the truck I use 31x10.5R15. That is between 2 to 3 inches taller a little wider than what it left the factory with. I went taller for less rotations per mile and wider for the load rating.
euromodder 09-11-2011 07:02 PM
I'm running the very popular 205/55/16 24.87 in 631.69 mm diameter
Can't do a range of tyres in Europe without this size.
(As an OEM alternative to the stock 195/65/15 24.98 in 634.49 mm.)
In Belgium, we're limited to - 2 % and + 1,5 % differences in tire diameter.
It definitely needs testing then. :cool:
echoRS 09-11-2011 08:10 PM
Dumb question everyone,
has anyone noted a significant gain in MPG's due to lower cruising RPM's with bigger wheels, in spite of possible losses in aerodynamics and gains in weight?
SentraSE-R 09-11-2011 10:04 PM
Yes. Tall tire test. Note page 1 of that thread shows the heavier, less aerodynamic wheels/tires don't give significantly worse performance than the OEM stockers.
