What to improve in VW Golf Mk4?
Currently I'm achieving around 4L/100km(59MPG) at 90km/h(55mph).
Is there any way to improve this with stealth aero mods? |
with stealth
I was thinking in grill blocks, underbody smoothing with flat panels, airdam,..
Isn't it effective in this kind of car? |
this kind
That said,you could do some things that would really make a difference,but none of it would be stealthly.All the mods would be immediately obvious to the most casual of viewers. Lower drag is about the 'look.' From where you're starting from,all the low-hanging fruit is already picked. |
Ok, I didn't knew it was already that optimized. I used to think that my Golf was a brick with wheels.
What you think about using using CFD analysis to try some tiny bits and see how effective they are? I already have a model of my car that I could use for that, but need some ideas to start. https://imagizer.imageshack.com/img921/6470/VXNWxG.png |
CFD
Thanks, so nothing I can do. I can't make it road legal here in Portugal that way.
can do
Who defines stealth? As they say you can not see what you do not know. Stance and plasma actuators* might do a lot. VW engineered to a general use case. Your example might be re-optimized for a more specific case. Countershaded camouflage*? Quote:
*Details on request. |
Mk4 like the 1.8L turbo motor?
