Old 09-23-2010, 11:12 PM   #1 (permalink)
5speed5's Avatar
TBSS - '08 Chevrolet Trailblazer SS 2WD
90 day: 19.36 mpg (US)
Wife's car - '09 Chevrolet Impala SS
90 day: 22.96 mpg (US)
Big Blue Hippo - '06 Chevrolet HHR 2LT
90 day: 45.99 mpg (US)
Opinions on my grill block plans, please? (pics inside)
Here is the front end of my truck as it is currently:
This is what I had planned to do (imagine the black is tape or some
other material):
In your experience will that leave enough cool air coming in for an
everyday driver (no towing and only hauling relatively light loads)?
thanks,
-Tim
Edit: I don't know why the pictures were different sizes.
Daily driver:
Old 09-24-2010, 12:17 AM   #2 (permalink)
cmj
Honda - '96 Honda Civic EX
90 day: 36.12 mpg (US)
With the massive fan on the front of that motor, I'm sure that will leave plenty enough air flow for the radiator.
Old 09-24-2010, 12:38 AM   #3 (permalink)
5speed5's Avatar
I've mentioned it elsewhere, but I should mention in this thread that I've
removed the mechanical clutch fan and have installed a single 16"
electric fan that is thermostatically controlled. I got a good one and it
moves a lot of air, but I'm hoping it won't have to come on very often in
my mostly highway commute.
Daily driver:
Old 09-24-2010, 03:20 AM   #4 (permalink)
Get a Scangauge and keep an eye on temperature
Old 09-24-2010, 08:06 AM   #5 (permalink)
Start with blocking the upper opening, and seal the hood gap with the squishy foam gasket from the home center. Then I'd try blocking the middle opening, as well. If possible, I'd run it with just the lowest opening unblocked. By deflecting as much air as possible up and over the (relatively) smooth body; and prevent as much air as possible from going under the truck; which is much rougher.
Is there a gap between the spoiler and the bottom edge of the radiator? If so, you can block it off which forces all the air coming into the grill to go through the radiator. It may well be open because there is way too much air coming through the three grill openings. You can "tune" things to leat only as much air in through the grill as needed, but then "use" all of that air to cool the radiator.
By having the air intake near or just below the stagnant point is the most efficient, I think.
Old 09-24-2010, 08:24 AM   #6 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Talking
The Ultra-Gauge is currently a better value and gives you more gauges to see at one time.
Old 09-24-2010, 12:38 PM   #7 (permalink)
Odd - '04 Ford Ranger
90 day: 33.29 mpg (US)
I second this.
Old 09-24-2010, 01:50 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
5speed5 -
What Neil said.
CarloSW2
American Solar Energy Society
Old 09-24-2010, 03:15 PM   #9 (permalink)
Never heard of that. Thanks
Old 09-24-2010, 04:03 PM   #10 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Thanks for the ultragauge link. I ordered one.
Noah Webster, 1787
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 11:55 AM
Opinions on grill block options sl2eggplant Aerodynamics 5 06-15-2010 11:42 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
