07-20-2016, 12:23 PM
what are these stuck on Aero thingies?
I've seen this guy on the way to work for a couple years.
kinda curious what these things are and if/how they work?
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
07-20-2016, 12:26 PM
You somehow missed all the conversations about air tabs?
07-20-2016, 12:32 PM
yes,
mr 11,xxx posts, I have missed all the OLD conversations about something that I have never seen or known what to call them
07-20-2016, 12:42 PM
thanks FRANK LEE
even though you were being a condescending ass, you did help me by providing a term to look up
Airtab | Aerodynamic Fuel Savers | How Airtabs Work
they claim that they can help with more than just fuel
Spray Reduction and Stability
Drivers report improved mirror visibility in rain or snow conditions yielding safer lane changes and better visibility for other road users. Improved stability and handling in windy conditions is reported by all drivers. This reduces driver workload, stress and fatigue
Road Grime Reduction
Because Airtabs™ alter the airflow at the rear of the vehicle, the partial vacuum there is reduced. There is less accumulation of road grime or snow. Less road grime means advertising remains more visible and the company’s image is enhanced. Less snow build up means less weight to haul and conspicuity tape, tail, running and brake lights, especially low temp LEDs, stay visible longer.
07-20-2016, 12:45 PM
I am always here to help. Remember that you ungrateful snot.
07-20-2016, 12:50 PM
Aero Deshi
They're vortex generators. It is considered by some, myself included, to be a fad device. The most effective aspect of the design is to make money for the people selling them. They have legitimate uses on aircraft, but on ground transport no one has really shown them to have a great effect, if any.
They are purported to help maintain attached flow longer to help reduce drag, or to allow the air to fill in the void behind a vehicle faster thus reducing drag.
2 basic things working against them are:
They are purported to create a turbulent boundary layer which helps to create attached flow...well, all ground vehicles have a continuous turbulent boundary layer, there really isn't laminar flow on ground vehicles. And that's OK.
There is a huge volume of air that is affected by the passing of a vehicle through it, it is NOT just the air rushing over the 2 inches above the surface of the vehicle that is moved about but several 10's of feet of air around it and many hundreds of feet behind that all matter. The VG's are essentially blades of grass in a hurricane breeze and really cannot alter enough of the flow of air in such a way as to make a difference.
Search "vortex generators" here in ecomodder, the subject has been thoroughly hashed out several times.
Like HHO, this is a subject of often contentious debate. I only hope it leads you to further try and learn the basics of aerodynamics so you can understand that these are kazoos trying to be in the Philharmonic.
The Following 3 Users Say Thank You to ChazInMT For This Useful Post:
07-20-2016, 12:53 PM
Aero Deshi
Well I see the contentiousness is faster than my lousy ability to type. I thought I was going to be the first to answer.
The Following 2 Users Say Thank You to ChazInMT For This Useful Post:
07-20-2016, 12:57 PM
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Come on guys. Be nice.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
07-20-2016, 01:06 PM
#9 (permalink)
Rat Racer
That is Frank Lee being nice.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 8 Users Say Thank You to Fat Charlie For This Useful Post:
07-20-2016, 01:08 PM
#10 (permalink)
Lolz!
