Old 04-26-2011, 04:28 PM   #1 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
What would be an alternative to rubber tires?
It takes approximately 7 gallons of oil, both in the formation of synthetic rubber and in energy, to produce 1 tire. (sited here: RMA: Rubber FAQs)
I have been wondering: What would be green, oil free alternatives to rubber tires (considering our access to natural rubber is pretty much none)?
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 04-26-2011, 04:51 PM   #2 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Crr .0001-.0020
The Following 2 Users Say Thank You to dennyt For This Useful Post:
RobertSmalls (04-26-2011), theycallmeebryan (04-26-2011)
Old 04-26-2011, 04:55 PM   #3 (permalink)
Leather?
Old 04-26-2011, 05:02 PM   #4 (permalink)
Send a message via MSN to markweatherill
Anti gravity! Of course, Big Oil has been suppressing this for years.
Old 04-26-2011, 06:03 PM   #5 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
28 gallons of oil to go 50,000 miles seems pretty good to me, 1785 miles per gallon for your tires.
I think if you want to make a larger impact getting low rolling resistance tires is going to off set the oil used to make the tires more then the increased rolling resistance of a sub par rubber compound.
Or you can take the train.
Old 04-26-2011, 06:04 PM   #6 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Can't say I'm attracted by the idea
Old 04-26-2011, 07:05 PM   #7 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Bearing in mind the amount of energy required to produce wooden wagon wheels / leather tires / moon buggy spring arrays / tofu twheels, I'd say synthetic rubber tires are an absolute bargain considering how long they last.
Old 04-26-2011, 07:23 PM   #8 (permalink)
euromodder's Avatar
The Michelin Tweel uses a lot less rubber for starters, and what's on there should last longer
Old 04-26-2011, 07:59 PM   #9 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
There isn't an alternative if you live in PA - the law requires pneumatic rubber tires on passenger cars.
Old 04-28-2011, 02:09 PM   #10 (permalink)
Tires are pretty high-tech items already.
The rubber content is much lower than you expect. There is substantial weight in reinforcing fibers (steel, aramid/Kevlar, polyester). The "rubber" part is heavily filled with carbon (likely created from oil, but not certainly) and minerals (largely silica). And the polymer part is a complex mix of rubbers.
I don't know how you would fairly allocate the "oil cost" of a tire. I do know that almost everytime I see an estimate like that from an "environmentalist", it's a lie created by multiplying mis-matched numbers. ("Save two gallons of water by turning off the tap when you brush your teeth." Sure...) They should be working to get fair comparisons for tire compounds. (How can you find a sticky tire with long life and good energy return?) Not say "everything you do is bad" .
