Old 09-09-2014, 03:33 AM   #1 (permalink)
Mazda 626 - '80 Mazda 626 Base
What's better: Large or small alternator?
A quick theoretical question for the experts.
If one must keep an alternator, what is better--A larger one that charges on/off or a small one that is almost always charging the battery?
My car will have an almost constant electrical load, as low beams are required over here.
Old 09-09-2014, 05:00 AM   #2 (permalink)
Smaller. Alternators are more efficient at higher loads.
You may want to look into alternator modifications if you have one outside the car that you're going to put in though, replacing the diodes with active rectifiers should give a very big efficiency boost.
Old 09-09-2014, 06:05 AM   #3 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
It should be legal now in Poland to drive with only front facing DRLs.
LED-versions can draw as little as 8w.
Old 09-09-2014, 07:08 PM   #4 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
You could put a switch so the larger alternator is charging only during idle and engine braking.
- Tony
