Old 02-07-2015, 05:55 PM   #21 (permalink)
Yaris - '07 Toyota Yaris hatchback
90 day: 34.85 mpg (US)
What do you mean by "freespin"? When I jack up my car and spin a wheel by hand, it only spins for about 2 seconds.
Old 02-07-2015, 06:05 PM   #22 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
So take your bearing stuff seriously it affects your fuel consumption!
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 02-07-2015, 06:07 PM   #23 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
yes car tires free spin is that jack up your tire and give your max speed to the tire with your hands. Max start speed you can give depends on the wheel weigth, your brake friction so brakes are on and your bearing friction and the power you have in your hands.
If you have a front wheel driven all all wheer drive car ofcourse the tire where you have drive axles dont spin but effect are same you just cannot measure them easily. That is why most people say they effect are not big with car bearings, but if you look at them so closely as those roller skate bearings same things happen also there and the forces are greater.
On wheels where there is no drive axles a working tire should roll 7+ seconds or in my opinion there is something wrong with it with brakes or bearings wise or both. you can get that time easily to 16 seconds with little bit of adjustments.
You can also use those same oils in your car bearings than roller skates if you modify them and add few extra seals etc...
http://en.wikipedia.org/wiki/Fuel_ec...ows_in_car.svg
About 5% bearings friction effect to fuel consumption on highway is something that you can change.
