Hi
I would like to know your opinion on two different types of wheel covers.
I understand that consensus is, that completely smooth wheel cover without any holes is the best option drag-wise.
But recently I have come across an interview with Mercedes aerodynamicist who worked on CLA and he said that completely smooth wheels are good, but wheels with correctly placed holes are even better.
That got me confused and now I'm trying to figure out what he meant by that.
Do you think that it is aerodynamically beneficial to have some airflow through the rim and wheel cover or is it good only for brake cooling and actually makes drag coefficient worse?
I have these two options on my car:
This quite smooth wheel cover with blanked holes
or this Mercedes wheel cover which is basically a small radial fan and scaled down version of this:
So what do you think?
Which one should I use if lowest drag coefficient is what I'm after?
