Old 08-29-2012, 08:50 PM   #1 (permalink)
royanddoreen's Avatar
z - '03 nissan 350z touring
90 day: 36.21 mpg (US)
Diniro - '18 Kia Niro Ex
90 day: 47.99 mpg (US)
5% larger tires (effect on odometer/MPG calculations?)
If I am using 5% larger circumference tires wouldn't this mean instead of getting 30 mpg I would of actually traveled 31.5 miles meaning 31.5 mpg?
Old 08-29-2012, 09:27 PM   #2 (permalink)
wrx4me...
no worries - '91 Subaru legacy L
90 day: 31.45 mpg (US)
weevee - '08 suzuki vstrom dl650
90 day: 61.22 mpg (US)
wrx - '09 Subaru wrx sedan
90 day: 29.8 mpg (US)
Big Bright Green Pleasure Machine - '09 kawasaki ninja 250 se
Connie - '09 kawasaki concours
Sounds right to me. Taller tires should should make the odometer show fewer miles traveled than actual and any mpg calculation based on the measured miles be under reported.
The Following User Says Thank You to thomason2wheels For This Useful Post:
royanddoreen (08-30-2012)
Old 08-29-2012, 09:51 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
yes, that is correct.
Which is why a scangauge is so wonderful.
It can be calibrated to the correct numbers.
I use my gps to get the exact distance traveled for my scangauge calibration.
As a note: I switch to metric on the gps and scangauge. It's more precise.
Then switch back to miles after setting it.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-30-2012, 09:47 AM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
That assumes that the tires are otherwise the same. If you have a different make and/or model of tire, there will be differences in rolling resistance - and some of those differences can be large enough to offset any gain you get due to diameter.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 01-20-2013, 02:50 PM   #5 (permalink)
I went from 26.7" o.d. Potenza re040 soft perfomance tires to 28" bridgestone blizzacks. The rr seems to be improved to my surprise and the lower final drive a bonus. The blizzacks are a lighter wheel tire package and my mileage has been improved greatly!!
Old 01-20-2013, 05:57 PM   #6 (permalink)
Jenny - '02 Chevrolet Prizm Lsi
90 day: 25.82 mpg (US)
Crowley - '23 Ford Maverick XLT
90 day: 28.31 mpg (US)
You might be seeing better gains than you think. You gotta find out the difference in circumfrence, not o.d. I put 225/75-15's on my ranger instead of 225/70-14's and those are under 2 inches taller. Go to a tire size calculator (just google search it) and enter your stock size and the new size and it will tell you what percentage it throws off your speedometer (and therefore your odometer). In my case that less than 2 inch o.d. Was worth 7.11%, so now when I enter my mileage I multiply the odometer reading by 1.0711 and get actual miles driven
Old 01-20-2013, 06:25 PM   #7 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
The stock odometer may not be accurate...do a gps distance run and see what your odometer shows compaired to gps distance....gps speed to speedometer is not the same as distance
Old 01-20-2013, 06:47 PM   #8 (permalink)
I have a scanguage and I have speed ajusted properly. I calculated from my gear ratios which shows 2070 rpm at 60 mph.
Old 01-20-2013, 07:16 PM   #9 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
Absolutely correct.
My car had 50 series tyres when bought ( 55 series is standard).
When checked against my GPS over my 52 kilometer commute, the odometer was correct and the speedo fast.
After changing to 60 series tyres, my odometer is 5.7% slow and the speedo about 1% slow.
When calculating my fuel consumption I now multiply the odometer reading by 1.057.
As it happens, I've gained about 5% FE, probably due as much to the Kumho KU25 to Pirelli P6 change as to the size change.
Old 01-20-2013, 10:11 PM   #10 (permalink)
mcrews's Avatar
Imagine that!!!!
Lowering the final rpm at cruise REALLY does work!
ECO MODS PERFORMED:
First: ScangaugeII
