Old 11-06-2014, 04:43 PM   #21 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
P+g is tricky for me with the slush box. I usually do a steady throttle input up and down the hill unless I have an unusually steep grade.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 11-06-2014, 04:45 PM   #22 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Originally Posted by dirtydave View Post
What if you have much higher RPM's? 2800 at 60MPH?
That's where I'm at. 2850 to be precise.
P&G should help even more, the worse the gearing. In my Del Sol, in places where I could cruise at ~30mpg steady state, I could get 50+mpg with aggressive P&G because of the huge losses from screaming down the highway at 4000+rpm with low load.
Yep. P&G helps even more the worse your gearing is, and the more overpowered your engine is. Compared to the Metro, I have both - poor gearing and a big engine.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
dirtydave (11-06-2014)
Old 11-07-2014, 05:02 PM   #23 (permalink)
I never glide up a hill unless it's a hill I can't really tell is a hill, because my engine gets about 50%-60% load in 5th when I can tell there's an incline and that's good enough for me.
Old 11-07-2014, 05:04 PM   #24 (permalink)
Upshift!
lol, into Reverse? :P That's the gear under 5th for me, which makes the engine spin at 3250rpm for 60mph.
Old 11-07-2014, 08:32 PM   #25 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Just hit the handbrake first
Old 11-07-2014, 08:48 PM   #26 (permalink)
Team Turbocharged!
Pickups
Originally Posted by johnlvs2run View Post
That's exactly what I do, except dfco uphills because there's not enough time to keep shifting, and steep downhills, and eonc on the flat and moderate downhills. I'm planning to use a kill switch and eofc my next trip and see what happens. I still compare dwl up hills sometimes and feel that p&dfco gives me better results, keeping in mind my civic has a relatively high rpm.
I have a feeling this is wrong. The reason P&G works is it maintains momentum, whereas DFCO doesn't. Keep in mind that OBD instrumentation is woefully inaccurate most of the time. When I first got my TDI which has virtually no engine braking (you can barely tell if it's in gear or neutral - simular effect to turning on the A/C while DFOC'ing a normal car), I tried P&G in DFCO for the first tanks, but P&G in neutral (EOnC) netted clearly better tank to tank results, even though SGII showed the opposite effect.
