Old 06-10-2019, 09:28 PM   #21 (permalink)
Redneck Ecomodder
Originally Posted by RustyLugNut View Post
In the 11 years since the first posting a LOT has been learned . Your "obvious" information is hardly the answer to the original question. Work by forum members such as Ivey and pgfpro show manipulation of variables can change combustion in a spark ignited gasoline engine. I relish the re-visitation of the subject.
I've run gasoline in a spark ignited engine with 20:1 compression ratio by messing with the "obvious". pgfpro has gone even higher with dynamic ratios exceeding 30:1. How? By running much leaner combustion mixtures than even Honda's Lean-burn engines. Go look up his work on various threads. It's deep reading if you know a thing or two about combustion thermodynamics and thermo-chemistry. Its simply outright fun if you don't.
Sounds interesting for sure, I'll look into it
gasoline self ignite
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Gas theft SVOboy The Lounge 34 06-14-2009 09:12 AM
I burned 160L of deisel and 80L of gas... MazdaMatt Success Stories 8 02-20-2009 10:11 AM
Gas as a % of income boxchain The Lounge 23 06-11-2008 07:59 AM
