Originally Posted by Slow_s10
Have you ever heard of the Hartley V8s? They are 2.8L V8s that redline at 10,000 rpm, make around 400 hp and only weigh like 200 pounds. It's basically two Hyabusa V4 motorcycle engines stuck together. They're pretty nutty... and crazy expensive.
But if that's not quite crazy enough, they also have bored out versions 2.9L and 3.0L that make 450hp, and 500hp respectfully, and if you really want to go nuts they even make twin turbocharged versions that make up to 1000hp. Heaven forbid I ever win the lottery because I would buy a stack of them.
Good luck with that.
Q: Can I buy a H1 or H2 engine?
A: Probably not now unless you are an existing customer.
As of March 2012, the H1 and H2 engine technology has been sold. The new owner will further develop the technology for race applications and plans to offer it to other markets in 2013. Hartley Enterprises retains the rights to build these engines in limited numbers for select existing customers and special projects in the US. All projects are taken for 2013.
