Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 10-21-2012, 07:43 PM   #11 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by whostean View Post
"It runs on batteries and electric generators that are recharged by a fan at the front of the vehicle and two ‘solar energy wings’ on the back that sustain electricity generation"
If those solar panels are good for a mile per day of range then what they say could be 100% true... if the fan idea really does work then why have solar panels at all?
Old 10-21-2012, 10:53 PM   #12 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Sorry to bring this thread back from the grave, but I was under the impression this guy's car only used the wind turbine to recharge his battery?
Whostean, ya do realize that the energy required to run a turbine has to come from the motor of the car, so it would be a perpetual motion machine for a turbine powered generator to charge the battery to run the motor to push the car to make wind to run the turbine to charge the battery to run the motor.....if you reach down and try to pick yourself up by your own shoelaces you get where the problem lies within this system.
The Following User Says Thank You to ChazInMT For This Useful Post:
Ryland (10-23-2012)
Old 10-22-2012, 01:22 PM   #13 (permalink)
Originally Posted by ChazInMT View Post
Whostean, ya do realize that the energy required to run a turbine has to come from the motor of the car...
No, at least not if I understand it correctly. The energy comes from whatever wind is blowing when you subtract the motion of the car.
One way to think about this is if you took the turbine off the car, put it in your yard, and used it to charge batteries. That would work, wouldn't it? So why wouldn't it work with the turbine on the car? Of course efficiency is another matter :-)
Old 10-22-2012, 02:34 PM   #14 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
How do you separate it from the drag induced by said wind? Even if the turbine is 100% efficient, that nets 0 gain.
I'm not coasting, I'm shifting slowly.
Old 10-22-2012, 03:44 PM   #15 (permalink)
Civic - '09 Honda Civic LX
90 day: 33.15 mpg (US)
And the theoretical limit for a wind turbine is ~67% efficiency. After that, not enough air is making it through the turbine to actually turn it.
The only way this could work is with a retractable air dam that only opens when braking. Otherwise any headwind benefits would be swallowed by the increased drag to the tune of ~1.5 [unit] lost per [unit] gained.
... besides, it's from FOX News...
The Following User Says Thank You to zapato For This Useful Post:
UFO (10-23-2012)
Old 10-22-2012, 08:36 PM   #16 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
The full scale models i saw that worked used the prop attached directly to the wheels to go into the wind.
this is a proven unicorn, as for charging batteries i can't say I ever noticed that on any of the working models in existence.
Old 10-22-2012, 11:18 PM   #17 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Here are the real wind powered cars: The remarkable first race for wind-powered vehicles
Old 10-22-2012, 11:52 PM   #18 (permalink)
Just think about it in steps. Say you've got your wind-powered vehicle, as in the picture in that linked article. It's stationary, and the wind is blowing - say a 30 mph headwind, just to make things simple. So the wind turbine can capture energy from a 30 mph wind at whatever efficiency, and transfer it to the wheels. This means that the vehicle starts moving at say 1 mph. Drag increases, but so does the apparent wind, which means the speed can keep increasing until the energy captured is just sufficient to overcome the total drag. Seems pretty obvious, and as the article shows, it does work.
Old 10-23-2012, 05:25 PM   #19 (permalink)
UFO
UFO's Avatar
It's fascinating and counter-intuitive.
Old 10-23-2012, 08:17 PM   #20 (permalink)
Ryland's Avatar
The problem is that at 30mph head wind it's going to take 1,400 watts to keep the car from moving backwards with the wind! so 1,400 watts just to keep it standing still and more energy to move it forward, so at that point it needs a prop that is larger then the frontal area of the car to generate enough power to move it forward and that would work if the wind generator was stationary next to the car with a long cord but as soon as you put that turbine on the car it increases the frontal area by the swept area of the turbine.
