Old 12-06-2018, 05:09 PM   #11 (permalink)
90 day: 57.12 mpg (US)
I believe I read somewhere the air speed close to the radiator is 1/6th of the velocity of the vehicle. Which, if true, means that the energy that could be derived of that fan is 1/6^3 of what it could have been in full wind.
Which is as close to nothing as anything; it would be a real challenge to harvest more than a few milliWatt out of that.
One could stick a row of TEGs to the radiator with a copper strip on the back and harvest a few Watt from the Seebeck effect. That in comparison would be way less uneffective.
I've been thinking about a micro turbine on the air intake to harvest energy from the vacuum draw on partial load, only to find no suitable turbines and generators for such a tiny draw exist. There's a potential of several hundred Watt there, but even that proved to be elusive.
I wish I could have given off a happier signal.
Old 12-08-2018, 10:36 AM   #12 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Interesting idea. On a gasoline powered engine, some of the restriction of the throttle body can be performed by the fan generator.
Old 12-08-2018, 02:42 PM   #13 (permalink)
I believe I read somewhere the air speed close to the radiator is 1/6th of the velocity of the vehicle. Which, if true, means that....
I can't confirm that, but it's been said that the opening of a properly ducted shroud should be 1/6th the area of the radiator itself.
One could perform a test with an electric fan, but before or after the radiator it would be like trying to breath with a pillow on your face.
