Old 07-26-2009, 07:37 AM   #1 (permalink)
Neon - '95 Dodge Neon
Last 3: 49.46 mpg (US)
Is anyone doing a hot air intake vs cold?
Hi, Is anyone doing a hot vs cold air intake and what are the results?
Old 07-26-2009, 07:49 AM   #2 (permalink)
blueflame's Avatar
Just about everyone here almost.
Refer to archives. Search with keywords
Old 07-26-2009, 10:37 AM   #3 (permalink)
Thanks!!!
Old 07-26-2009, 04:34 PM   #4 (permalink)
Yaris - '07 Toyota Yaris Liftback
YAris comes stock with a pretty hot intake lol
Old 07-26-2009, 10:56 PM   #5 (permalink)
All 80s and 90s non turbo volvos have a thermostatically controller hot/cold intake that usually fails on the hot only side after 10 years. Fixing the intake to breath only cold air all the time usually nets 10-15% FE improvement as well as power.
Old 07-27-2009, 07:34 AM   #6 (permalink)
blueflame's Avatar
I get 10-15% more with hot air, especially in winter
Old 07-27-2009, 08:18 AM   #7 (permalink)
Fledgeling Aeromodder
Brillig's Avatar
Lillian - '93 Ford Escort Wagon
90 day: 34.98 mpg (US)
I'm working on a hot/cold 'switchable' intake to do A/B testing on my 93 escort wagon. I intend to do a/b testing for a couple of months ('full tank' method of measuring gas consumption).
Side issue - the air intake has a restriction before the filter, which necks down the air channel to approximately a 1" throat - it is part of a plastic channel which resembles a human 'stomach with intestine', with a large vacuum reservoir just after the restriction.
I removed this and see immediate improvements in 5th gear acceleration, pulling power. Less load on the engine with freer air supply is my guess.
Where can I get the 1.21 GIGAWATTS of electricity that I need?
Old 07-27-2009, 08:44 AM   #8 (permalink)
blueflame's Avatar
Intake restriction often improves torque. And FE too I think
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Subaru Outback Hot Air Intake Results brucey EcoModding Central 22 12-10-2008 07:41 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 10:01 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
