Woodgas meetup 2021
I probably should have mentioned it before :o , but DriveonWood.com is having a meetup in Argos, IN June 3-6. I am attending as I've been curious about converting (even if it's just for curiosities sake) the mercury and it's ~2 hrs from me. If anyone has any questions I can try to find some answers. I've done some research so I might be able to answer basic questions already, but if not I can try to get better ones at the event.
Wood pellets?
Particulate filters? |
Most of the forum users that run wood (vs charcoal) have a wood 'chunker' to turn it into cubes of a relatively consistent size. Converted pickups (don't have to have a compact setup) use wet hay in a barrel. The particulates stick in the water and when the engine is shutoff the water drains off the hay into a tank.
This has me imagining George Poteet's '32 Ford bobber with an oak barrel in back. :thumbup:
https://daytonwirewheels.com/images/...rge_poteet.jpg https://daytonwirewheels.com/gallery..._1932_ford.php |
Wood gas is interesting to say the least, but nowadays I'd rather try it for stationary purposes as a replacement for LPG instead of resorting to it as a motor fuel.
How many mpt (miles per tree) do people get?
They say 22 lbs of dry wood is about a gallon of gas. So... divide by 3, cube it, then take the square root...
¯\_(ツ)_/¯ I will try to get a general answer. Most like to convert the v8 dakota (90's I think) so I imagine most will be the same vehicle for a little more consistent data. If this gives you any idea they are making sure to bring extra wood in case anyone who drove a far distance needs any for the return trip. |
A gallon of gasoline has around 128,000 btu per pound.
A pound of dry wood has about 10,000 btu per pound. But wood gas is supposed to be a lot less efficient than gasoline or propane. |
A gallon of gasoline is ~6lbs so that would be 20k BTUs per lb of gasoline vs 10k for wood (I didn't double check the BTU for wood)
