Old 06-07-2011, 07:40 AM   #11 (permalink)
piers.singer's Avatar
I like the grill blocks a lot, very slick and mean-looking Please do keep us up-to-date with your FE figures.
Spoken like a champion. Oh no, disaster!
The Following User Says Thank You to piers.singer For This Useful Post:
d0sitmatr (06-08-2011)
Old 06-07-2011, 01:32 PM   #12 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
Originally Posted by Joenavy85 View Post
some clear plexi over those parachutes that you have for fog lights
without a doubt that is the next thing on my "to-do" list
not sure how Im going to be able to keep track of my FE except on a tank/tank basis as I have to save every penny I can at the moment to buy a truck for work. so I wont be getting a scangauge as soon as planned.
~Mike
Old 06-07-2011, 11:11 PM   #13 (permalink)
Work In Progress
Black Knight - '08 Toyota Yaris
Send a message via AIM to honestabe
You really should add your new car to the EM Garage and track your fuel economy that way. It's a good tool to se how you're doing.
The Following User Says Thank You to honestabe For This Useful Post:
Old 06-08-2011, 12:16 AM   #14 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
thanks for reminding me about that.
~Mike
Old 06-08-2011, 10:17 AM   #15 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
so I have a 2+ hr (1 way) trip planned on the 14th as I have to run a couple of people to Ft Myers. I will probably run around 60mph most of the way as that is the spd limit, unless I come across a tractor trailer I can draft. I also am going to remove the upper GB as before I installed that, I never experienced the gurgling sound from the OF. I considered the lower GB, but honestly I think its doing the most good.
Im going to try and get the fog covers done before then.
~Mike
Old 06-08-2011, 06:57 PM   #16 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
OF? as in OverFlow? need to add this to the acronym page
Old 06-08-2011, 06:58 PM   #17 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
yep, over flow
~Mike
Old 06-08-2011, 08:28 PM   #18 (permalink)
ok, just checking, that was all i could think of that related to removal of a grill block
Old 06-10-2011, 12:05 AM   #19 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
some more testing, by removing the upper block and the OF doesnt bubble, so Im thinking that over the summer I will leave the upper block off.
next up, lower air dam, the mp5 has a small (2' across) one already in place that I can just hook onto and extend down and out to include the front tires, I have more than enough coro that I may even be able to make a front belly pan, but not sure if I want to use coro for that, Id prefer something a little more durable
~Mike
Old 06-16-2011, 12:50 PM   #20 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
after some more testing, and a 6 hr trip, 1/3 of which was city, I had put the upper grill block on and removed the lower. Ive decided the upper grill block is the one that is more restricting to my airflow and is the cause of the bubbling in my over flow. plus, I think it isnt as affective of helping create a more aero front end.
so I removed it (again) and put the lower GB back on.
I have a trip planned to Orlando (about 2-2.5 hrs 1 way) to pick up a set of OEM side skirts, which Im hoping will help to clean up the flow around the sides. plus Im thinking it will give me something easier to build upon if I want to enclose the underside partially.
although looking at the belly of the mp5, its pretty clean (or Im just too used to trucks....)
either way, I am going to put a front pan on, while it is pretty clean under the front there is more than enough room for improvement
also of note, my 2nd tank of gas was all city/town driving, and I still managed to net 29mpg, and that will only improve as I have an SG ii on the way !
~Mike
