03-25-2019, 11:31 PM
Advice on rolling stops or full stops
In the last month or so I have doubled down on my---well its not really hypermiling, because I don't do all the dozens of tips listed at the 100 tips link at the top, but I was able to get 26.1 on an out of town freeway trip, in a new to me 2006 Highlander Hybrid, when the adjusted freeway EPA MPG was 25. So I am doing well in remedial Hypermiling 101.
At any rate, I have noticed in the last month, that I've also been doing a lot more of what I call the California Rolling Stop, instead of a full stop at a sign.
What is the experience & advice of people here? Do you folks do this, or do you come to a full stop, even when there is nobody there? Or do you work on a compromise, like a full stop for a split second, before moving on? I don't know if that would require any less gas, than emerging from a full stop for 3 full seconds, which is how I learned to stop in drivers ed way back when.
03-26-2019, 01:57 AM
Master procastinator
A stop sign is a stop sign. It's there for a reason.
In my opinion, safety goes before saving a drop or two of fuel.
Reason: Corrected typo
03-26-2019, 04:58 AM
I roll when I'm in the middle of nowhere. YMMV
03-26-2019, 07:36 AM
How much does a ticket for running a stop sign cost?
03-26-2019, 07:48 AM
Never got one. I dunno.
03-26-2019, 10:57 AM
Unless your rolling stop is at 15 miles per hour, it's not going to save that much fuel. Do I rolling stop? Perhaps very slightly sometimes but I'm very nearly stopped, and that's more to do with not wanting the full "jerk" of stopping and to save a second, not to save fuel.
If you've got a hybrid it's already recapturing some of that stopping energy.
Failing to obey a traffic control device (stop sign) is a hefty ticket compared to speeding, and is seen as way more serious.
03-26-2019, 11:23 AM
Rat Racer
If my engine's running I'd rather come up from 1 than from zero.
A nearly compliant rolling stop is a good, solid deceleration to the line with an extra push on the brake at the line to give the car more decel and a dip. With the dip it noses down and rocks back. At a low enough speed it looks good and conserves half a smidgen of momentum.
If my engine's off, I bump start as part of coming to a halt, give the engine half a moment to realize it's awake and then move on.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
03-26-2019, 12:56 PM
If I can conserve enough momentum to stay out of 1st gear at intersections without dropping the RPMs below idle, gas is saved. Seems pretty simple.
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
03-26-2019, 05:01 PM
EcoModding flying lizard
I almost always come to a full stop. Only times I skip it are when people are racing up behind me, threatening to rear end me. I'll pull away about 3/4 of a second after stopping. If you stop and wait for 3 seconds people here in Georgia will honk the **** out of you and/or crash into you.
It definitely doesn't help my mileage having to get the 3300 lbs rolling from 0, but it does help in not getting tickets. You never know when a cop may be watching. 0 tickets in 6 years and counting. I have had police threaten to throw me in jail, and falsely accuse me of "stopping traffic and drag racing" when I had a motorcycle break down on a road without a pulloff, but that is a little different...
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
03-26-2019, 06:27 PM
Rat Racer
The only time I got tagged was when I sawed through a chicane that had a stop sign at either end. I was only watching out for safety, not watching out for everywhere that had line of sight on me.
That was not hypermiling and nowhere near a rolling stop. It wasn't quite drifting either, but...
