Old 10-02-2023, 01:02 PM   #11 (permalink)
blownb310's Avatar
Saab EV - '19 Chevy Bolt EV LT
Pierre - '07 ZENN MC2 Base
Originally Posted by serialk11r View Post
Aluminum's melting point is too low, though typical brake pads also don't work at high temperature either. With cast iron rotors + high temp pads, performance is pretty acceptable.
Yes, but we are talking about an EV with a hypermiler driving. The rotors never get hot. The car will stop completely without touching the brake pedal. It's difficult to keep the rust off of them because they are seldom even used.
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
Old 10-02-2023, 01:58 PM   #12 (permalink)
Aluminum brake drums have steel inserts
I know the thread is about rotors not drums, but oil pan 4 opened the door.
"We're deeply sorry." -- Pfizer
blownb310 (10-02-2023), Piotrsko (10-03-2023)
Old 10-03-2023, 09:59 AM   #13 (permalink)
Need to also post in the other thread.
Old 10-03-2023, 01:38 PM   #14 (permalink)
There's another thread?
Please do post there.
Old 10-03-2023, 04:11 PM   #15 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
There are OEM Cars with OEM aluminum rotors
What was used by Honda?
For coorsion prevention stainless is best
Aluminum would probably work fine on the rears on pretty much every car in the road.
Also for temperature aluminum cools much faster
Old 10-05-2023, 05:35 PM   #16 (permalink)
I sold auto parts for a decade and the better rotors used nickel as an alloy. A EV is usually much heavier from battery weight. Regen and dynamic braking circuits save energy. Hydraulic brakes are also needed to stop quickly in an emergency. Even if you don't fully cross drill the rotor a pattern of shallow holes helps.
Old 10-05-2023, 06:58 PM   #17 (permalink)
I only remember OEM aluminium discs on motorcycles.
I would trust aluminium drums more, as they're less prone to bend than a disc, and aluminium is usually softer than steel.
Easier heat rejection was quite advantageous to overcome brake fading when Lada resorted to aluminium brake drums.
Old 10-05-2023, 08:56 PM   #18 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Which Honda? The 1st gen Insight had aluminum front calipers, and aluminum rear drums with a steel liner. Nothing special about the rotors.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
blownb310 (10-05-2023)
