10-02-2023, 01:02 PM
#11 (permalink)
Originally Posted by serialk11r
Aluminum's melting point is too low, though typical brake pads also don't work at high temperature either. With cast iron rotors + high temp pads, performance is pretty acceptable.
Yes, but we are talking about an EV with a hypermiler driving. The rotors never get hot. The car will stop completely without touching the brake pedal. It's difficult to keep the rust off of them because they are seldom even used.
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
10-02-2023, 01:58 PM
#12 (permalink)
Aluminum brake drums have steel inserts
I know the thread is about rotors not drums, but oil pan 4 opened the door.
10-03-2023, 09:59 AM
#13 (permalink)
Need to also post in the other thread.
10-03-2023, 01:38 PM
#14 (permalink)
There's another thread?
Please do post there.
10-03-2023, 04:11 PM
#15 (permalink)
home of the odd vehicles
There are OEM Cars with OEM aluminum rotors
What was used by Honda?
For coorsion prevention stainless is best
Aluminum would probably work fine on the rears on pretty much every car in the road.
Also for temperature aluminum cools much faster
10-05-2023, 05:35 PM
#16 (permalink)
I sold auto parts for a decade and the better rotors used nickel as an alloy. A EV is usually much heavier from battery weight. Regen and dynamic braking circuits save energy. Hydraulic brakes are also needed to stop quickly in an emergency. Even if you don't fully cross drill the rotor a pattern of shallow holes helps.
10-05-2023, 06:58 PM
#17 (permalink)
I only remember OEM aluminium discs on motorcycles.
I would trust aluminium drums more, as they're less prone to bend than a disc, and aluminium is usually softer than steel.
Easier heat rejection was quite advantageous to overcome brake fading when Lada resorted to aluminium brake drums.
10-05-2023, 08:56 PM
#18 (permalink)
Too many cars
Which Honda? The 1st gen Insight had aluminum front calipers, and aluminum rear drums with a steel liner. Nothing special about the rotors.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
