Old 01-11-2017, 10:09 AM   #21 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Vg's havs a local air flow directional dependency(can be as much as90° difference from 1 to the next)tuft testing is needed for proper application. VG will allow steeper change of angle with out loosing attached flow. Consider a 3D Printer to produce in house. (I see a short ROIwith the volume of VG'S needed as well as the capability to produce scale models for testing)
Are you running Road Trains? Single 53'? Triple 20' ? I assume you have many configurations.
The Canadian artical is interesting, I am still reading it (120pg).
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
craysus (01-12-2017)
Old 01-11-2017, 11:14 AM   #22 (permalink)
Dark Egg - '12 VW Touraeg
This paper shows the vortex generators hurt but they don't look the same as the littles ones I have seen.
https://www.google.com/url?sa=t&sour...Qs3Wg-JJm7lr0w
The Following 2 Users Say Thank You to Hersbird For This Useful Post:
craysus (01-12-2017), gumby79 (01-11-2017)
Old 01-11-2017, 02:47 PM   #23 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
The VG on top(1"x1"x1/8"x1'-1.5'aluminum angle) have a blunt front and rear (rectangular). There orientation is in the direction of travel. Travel and air flow direction seldom match at the rear especially at corners.
The fronts should be curved from bace up and back. Parallelogram with curved leading and trailing edges. Not like the side VGs.(trapezoid)
This is a poor example with witch to condemn all VGs. Poor fit and finish .In my opinion.
Former
87' Hyundai Excel
Old 01-11-2017, 04:50 PM   #24 (permalink)
They did have to make thier own on the fly but that was because none of the actual makers of the vortex generators for sale at the time wanted to supply their product to be tested in an actual wind tunnel on an actual truck. That sort of raises a red flag to me but it was back in 2006.
The Following User Says Thank You to Hersbird For This Useful Post:
Old 01-12-2017, 11:06 AM   #25 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
I see you have all the scientific links already. There are two links from my bookmarks (i am not affiliated with any of the companies, i just somehow like the product although i have never seen it in reality (central Europe is quite different place for big trucks, than Australia or America)
( homepage)
(homepage)
-they are probably much more expensive than home-built variant, but its insdustry delivered proven solution with all insurance etc.
The Following 2 Users Say Thank You to seifrob For This Useful Post:
craysus (01-12-2017), ThermionicScott (01-12-2017)
Old 01-12-2017, 01:38 PM   #26 (permalink)
Thanks for adding the wheel cover story. I'd thought of it but hadn't added it to the thread.
If we get off vortex generators maybe the OP will come back?
craysus (01-12-2017), Trucker John (01-15-2017)
Old 01-12-2017, 02:02 PM   #27 (permalink)
ScanGauge <3
ThermionicScott's Avatar
I'm a little skeptical of their "proprietary speed-sensing radar technology" -- seems more like it's held closed by a weak spring that gets defeated by a strong enough wake.
Best tank (so far): 32 MPG
The Following User Says Thank You to ThermionicScott For This Useful Post:
Old 01-12-2017, 02:40 PM   #28 (permalink)
We have the moon wheels already under trial.... Results are minimal at best on our current rigs... But that may be due to not enough supporting aero...
The trailers boat tails we can't use in Australia as we go over length by adding it on unfortunately
In relation vortex generators... Most of the vortex strikes seem to be a thing of the past.. With products causing twin closed vortices being used now... Eg airtab is one brand... We have them in use and can notice some mileage saving just when installed on last trailer... But I am still to trial on all the locations on the tractor and between trailer gaps etc... Once I find a decent supplier we will progress.
Other aero like replacement hoods to upgrade old poor aero designs from the manufacturer.. Aero mirrors.. Etc.. Still to be actioned as well.
Parasitic losses to the engine I am also starting to investigate... Things like the mechanically driven fan... And other things need to be rectified.. But it's a big work in progress...
I am also investigating tilting the radiator back with a electric fan behind it to reshape the aero of the front...
We can't use undertrays due to amount of wildlife.. (damn kangaroo's) so I can rule that out as well...
Old 01-12-2017, 03:08 PM   #29 (permalink)
Permanent Lurker
seifrob's Avatar
Originally Posted by ThermionicScott View Post
I'm a little skeptic of their "proprietary speed-sensing radar technology" -- seems more like it's held closed by a weak spring that gets defeated by a strong enough wake.
You know, it's not exactly lying, its marketing . :-)
(Reality agent: "Calm place close to countryside.", English translation: "Seven miles to the closest grocery store". No one will buy "horse ****s", but "environment friendly, biodegradable fertilizer")
OTOH it is proprietary and speed sensing so it's 66% true. ;-). Their PR did good job.
Originally Posted by craysus View Post
We have the moon wheels already under trial.... The trailers boat tails we can't use in Australia as we go over length by adding it on unfortunately
I was under the impression that foldable design had exception and the length restriction doesn't apply. Therefore it opens at speeds over city speed limit.
EDIT: I have checked. They claim they have "EXEMPT from U.S. DOT length restrictions" on their webpage. I know nothing about Australia though. But if it proves worth, maybe you can persuade them to get australian DOT approval too.
Last edited by seifrob; 01-12-2017 at 03:31 PM.. Reason: Grammar, check for exempt
The Following User Says Thank You to seifrob For This Useful Post:
Old 01-12-2017, 07:25 PM   #30 (permalink)
http://www.mgexp.com/phorum/read.php?1,1956757
Vee radiators were popular in the Brass Era, and lately with Porsche.
Accessing the Radiators
