Old 02-08-2017, 12:35 AM   #81 (permalink)
Here's a sketch I did for someone with a pickup truck. The idea is that the [conveyor belt/mudflap] material is only fastened along the legs of the U. My thinking is that only bounded on two edges it can deform and rebound more easily.
The angle could be increased to make a more upright wheel spat.
craysus (02-12-2017)
Old 02-08-2017, 02:10 AM   #82 (permalink)
You will have to lead my by the nose on that one..
Looks like a attempt to "boat tail" the mud flap?
Wouldnt a standard aero mudflap design work more efficienctly? (Designed to allow 75% of air to pass through the mudflap, thus reducing frontal area effectively..I consider a truck as having 12 mudflaps, each around 300x500mm size..(2sqm!!) which equates to around 50% of the frontal area of the truck...
If you consider the aeroflaps pass 75% of air through them, that reduces 2sqm of frontal impact area to around 0.5sqm...
Obviously this frontal impact area is NOT as severe as the front of the truck, as the air hitting it is "slower" due to being indirect..however even if the air is 50% velocity...it would have a huge impact..
Looks like around 1.5% improvement on the tractor, and 2% or so on the trailer just using them..
Now a boat tailed flap on the aero flaps...hmmmm...on a normal car/small truck might be beneficial.
I am looking to reduce amount of air under the truck (Using a front air dam under the bumper), and relive the amount behind the wheel wells..AND prevent air coming in from the sides with wheel covers...I doubt boat tails on mudflaps could be used?
Possibly missing something however !!
Old 02-08-2017, 02:58 PM   #83 (permalink)
Here is the aerodynamic ideal (impractical on a truck):
[IMG][/IMG]
Blisters around each tire. Here is the MG181:
Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - Sven7's Album: Aero vehicles - Picture
These are termed wheel spats rather than mudflaps. An example on a late model car:
http://ecomodder.com/forum/showthread.php/show-me-your-wheel-spats-13669.html#post231206
My proposal is in the middle ground. Think of it as a mudflap that is cupped or curled to stiffen it so it holds it's shape. It could be applied ahead of or behind a wheel, or both. Height maybe half the tire width?
Old 02-09-2017, 02:10 AM   #84 (permalink)
Some more light reading..
http://nparc.cisti-icist.nrc-cnrc.gc...3-9658934e59e0
Of note, looks like a trailer fairing would be beneficial..around 1.5% aero drag reduction (.75% fuel economy)
also, underbody plates between bumper and front axle, combined with TOP of chassis (behind cab) plates to prevent air entering into trailer gap ..around another 1% economy saving..
Would have to make the underbody plates pretty substantial however..possibly alloy checkerplate with a lot of bolts..otherwise a kangaroo will rip it off in short time..
Old 02-09-2017, 02:12 AM   #85 (permalink)
Latest spreadsheet with a number of improved estimates included..(Trying to get it as accurate as possible)
free upload pictures
Old 02-09-2017, 03:52 AM   #86 (permalink)
https://www.grimco.com/Catalog/Products/MAXmetal
Aluminum skins on HDPE plastic. Two different skin thicknesses, .15mm or .21mm, about like a beer can. Sheet sizes up to 5x10ft. Competitive products are Polymetal and Aluma-panel. Here are tests I did shearing, braking and rolling samples of Polymetal by hand:
The white stripe is an H-channel joining two pieces. Braking cracked the outer skin. I had less success trying to dimple it for recessed fastener heads.
craysus (02-12-2017), RustyLugNut (02-09-2017)
Old 02-09-2017, 03:36 PM   #87 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Hand holding
This spat is in front of the wheels and the flaws you're talking about ,go behind the wheels
A spat deflects the air around the flat surface of the tire with less energy.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Old 02-12-2017, 09:09 PM   #88 (permalink)
I am just waiting on my Engine modifications to finalise through testing..looking promising.
I am comparing 2 x different Hydrogen production methodologies (Excluding electrolysis due to the high inputs vs outputs), and both options look to be working well in preliminary testing. Both options have some small hurdles to overcome first prior to being finalised.
Water injection, testing so far has been insanely good, with 25-30% water injection on the test mule (medium Isuzu truck) ..We are expecting this to INCREASE to 30-35% when fully tuned..
Overall, the engine modifications with external fuels being added in may achieve a stacking effect around the 40%+ in fuel savings alone..add in the Aero and friction savings, and I might be able to achieve 60%+ savings ...
Very promising...
The Following User Says Thank You to craysus For This Useful Post:
gumby79 (02-13-2017)
Old 02-13-2017, 03:27 AM   #89 (permalink)
That's pretty amazing. Do you have any theory as to why everyone doesn't do it?
craysus (02-13-2017)
Old 02-13-2017, 03:58 AM   #90 (permalink)
None at all.... I have used it before without issues.... Major things to be wary of are fairly simple.... Eg if injecting pre turbo you WILL wear compressor vanes over time.... And it's not needed to inject there for economy..
Also obviously if you tune for water and the system fails or you run out of water it's not good.... But similarly running out of diesel ain't such a good idea either..
In cold climates freezing can be an issue..
In hard water areas you have to use processed water.... And with bottled water 3 times more expensive than diesel it's a turn off...
Probably few more things.. And of course fear of the unknown... Lots of people will be worried injecting water into a diesel as they k ow how bad it is if it's in the diesel fuel tank..
freebeard (02-14-2017)
