08-24-2023, 01:19 AM
#41 (permalink)
Originally Posted by j-c-c
Weight in these proportions and context, IMO is not a factor in this discussion.
Depending on where and how it's attached to the motorcycle, a much heavy windshield may affect handling.
08-24-2023, 02:13 AM
#42 (permalink)
How much weight difference are we talking (nobody is using say 3/8"? tempered glass,) we are not talking fighter jet wraparound large windscreens, and where are we mounting it that it is not mounted to same frame member as the front forks, which if heavy or of any weight, would dampen slightly crosswind effects on steering control. Size and shape IMO will impact steering far greater than any weight penalty.
08-24-2023, 11:00 AM
#43 (permalink)
applicable
Interesting, but not sure how applicable that was to the original discussion.
On the IHPVA drag table, for the image, 6th-down from the top, is a bicycle with a Grand Prix, racing-style wind screen, and it's Cd compared to the same bike without.
08-25-2023, 12:37 AM
#44 (permalink)
A windshield following the movement of the handlebar, instead of being fixed to a fairing, may also affect the handling, yet I'm not totally sure about it.
08-25-2023, 11:10 AM
#45 (permalink)
I found that windshields attached to the steering forks do cause steering inputs from crosswinds. It is a function of the lateral fin area, side drag coefficient, and the distance from the center of pressure to the steering axis. I attach all my fairings to the frame near the head tube. I get the best results using both a front fairing and a tail box.
The Following User Says Thank You to Grant-53 For This Useful Post:
08-27-2023, 12:55 AM
#46 (permalink)
This is from the opening post: " At highway speeds regarding mpg, in a full upright ride posture and at what point is a windscreen too big for mpg improvement?"
Your above IHPAVA reference is not likely highway speeds related, nor an upright position, nor sustainable for long in most cases being it's a crouched riding position behind a windscreen or maybe an obscure fairing.
I think this whole discussion should not lose sight of the "measurable vs significant" symmetry here.
08-28-2023, 10:39 AM
#47 (permalink)
AKA - Jason
This is from the opening post: "At highway speeds regarding mpg, in a full upright ride posture and at what point is a windscreen too big for mpg improvement?"
I gave you real world data in post #15. A barn door windshield is good for about 5% improvement in fuel economy.
08-28-2023, 10:52 AM
#48 (permalink)
Sorry, I was referring to the "6th down from the top" as the example given, My bad.
