Old 05-11-2015, 02:36 AM   #1 (permalink)
Crono's Avatar
Pizza Geo - '92 Geo Metro
Last 3: 47.52 mpg (US)
Blazing Glory - '07 Yamaha C3
90 day: 108.96 mpg (US)
The Beast - '86 Pontiac Subird
90 day: 15.6 mpg (US)
Mom's Firefly - '92 Pontiac Firefly
90 day: 35.65 mpg (US)
Noris - '08 Toyota Yaris
90 day: 35.45 mpg (US)
Mirage - '15 Mitsubishi Mirage
90 day: 48.11 mpg (US)
Japan - '08 Suzuki Alto
90 day: 45.88 mpg (US)
Doing an engine/transmission rebuild on my Metro. Anything worth considering?
I'm planning on getting my engine and transmission rebuilt in my '92 Geo Metro (3 cylinder). It's already got the shorter duration cam mod and the transmission from a 4 cylinder Metro. Is there anything else I might be able to do to help improve efficiency while I'm rebuilding it?
Old 05-11-2015, 06:14 AM   #2 (permalink)
Bump the compression, port match, 3-angle valve job, 2-ring xfi pistons, underdrive the belt-driven stuff.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
BabyDiesel (05-11-2015), Crono (05-24-2015)
Old 05-11-2015, 11:09 PM   #3 (permalink)
Engine block heater.
http://ecomodder.com/forum/showthrea...mer-23893.html
You don't have to go that extreme, standard 600w heater would be sufficient for a 3 cylinder engine.
http://ecomodder.com/forum/showthrea...ing-25512.html
File fit the rings to each bore. Keeping more air/fuel in the cylinders so it gets burned.
Also keeps fuel and combustion byproducts out of your oil, extending oil changes.
Crono (05-24-2015)
Old 05-11-2015, 11:55 PM   #4 (permalink)
DLC coating on the bearings. Or Microblue
The Following User Says Thank You to DIMS For This Useful Post:
Crono (05-24-2015)
Old 05-12-2015, 10:42 PM   #5 (permalink)
Coatings.
Coating engine internals with both friction reducing coatings as well as thermal barrier coatings can be a benefit.
Contact Swain Tech for service. If you want to try a DIY approach, Tech Line Coatings can help you out if you have a business license and you have the shop skills and patience.
Race Coatings | Swain Tech Coatings | Industrial Coatings | High Performance Racing Coatings
Tech Line Coatings | Automotive ( Hi-Performance ) Coatings
The Following User Says Thank You to RustyLugNut For This Useful Post:
Crono (05-24-2015)
Old 05-24-2015, 06:58 AM   #6 (permalink)
Crono's Avatar
Thanks for the ideas everyone, I'd forgotten about this thread since I don't post here often, but I read everything.
Old 05-24-2015, 07:57 AM   #7 (permalink)
Experienced UAW Mechanic
You'll spend more on that than if you just go to Pick-N-Pull and get 3 used examples of each. They should be good for at least 200K miles each, it's not hard to find them with half that.
Old 05-24-2015, 07:57 AM   #8 (permalink)
Not worth it.
Old 05-24-2015, 07:58 AM   #9 (permalink)
Too little results for too much cost. This stuff is best left to unlimited funded race efforts.
Old 05-24-2015, 08:00 AM   #10 (permalink)
Engine block heater. File fit the rings to each bore. Keeping more air/fuel in the cylinders so it gets burned.
Block heaters are for old diesels.
File-fit rings are for racing engines where more gap than standard helps against ring butting at extreme temps. Can't even get them for any 3-cylinder because nobody races them.
