Old 02-08-2010, 08:47 PM   This thread is in the EcoModder Project Library | #1 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
echo wheel skirt how to with pics.
This method requires you not being afraid to take a hacksaw to your inner fender lip. But it is really easy to do, and can be reversed if your careful. first pick 3 or 4 places on your fender that look like good support points for your skirt.Click image for larger version
ID:	5566 a hack saw or i used an air cutoff tool,Click image for larger version
ID:	5567 go slow and cut close to but not the visible fender lip.Click image for larger version
ID:	5568 then grab it with vicegrips and bend it down,gently!part of my fenderlip is plastic so i had to mount a bracket (homedepot truss strap)using self tapping metal screwsClick image for larger version
Name:	echoskirts bracket.JPG
ID:	5576 then take your metal/aluminum/plasticClick image for larger version
ID:	5569 and hold it up to the fender or tape it and reach around back with a marker, follow the fender opening. then depending on your materal cut it into the round shape, leaving room outside the line to curve/bend the material to close to the shape of your car body. and to clear your tire.Click image for larger version
ID:	5571 fit it into the opening and trim it as needed,drill holes into the tabs you bent down,hold the sheet up against the opening and mark your sheet and drill holes in it. then mount it with small srews,washers,and nuts.some photos of the finished product,not perfect,but im impatient and did it in around 2 1/2 hours, you can make yours look perfect if you take your time!Click image for larger version
ID:	5572,Click image for larger version
ID:	5573,Click image for larger version
ID:	5574, more mods and some aba when time and wind converage.
The Following 5 Users Say Thank You to moonmonkey For This Useful Post:
Christ (02-09-2010), johnnymac (03-27-2010), mcrews (03-22-2011), MetroMPG (02-09-2010), NeilBlanchard (03-22-2011)
Old 02-08-2010, 09:08 PM   #2 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
you;re working hard, moonmonkey.
what's next?
looks great, ya know.
single person car thread
The Following User Says Thank You to luvit For This Useful Post:
moonmonkey (02-08-2010)
Old 02-08-2010, 09:29 PM   #3 (permalink)
ecomonkey
thanks luvit, next is some refinements of my grill blocks, and a cable operated vent to regulate airflow in lower grill, then some molded boat tails for my tires, also lowering the car,maybe active? low rolling resistance tires soon (i have 2 maypops),, im going to get bored when im thru with all this.im still learning how to post this stuff,this is the first forum i,ve been on.but i will post diy's for all my remaining mods, maybe it will inspire thought on how to do some of this stuff. ill also create a echo mods thread when i figure it out.
Old 02-08-2010, 09:51 PM   #4 (permalink)
epic stock master
luvit's Avatar
come to ohio and mod my car in my snowy driveway. lol.
Old 02-08-2010, 10:26 PM   #5 (permalink)
Hi,
Looks very good! Did you consider extending them down further?
Old 02-08-2010, 10:26 PM   #6 (permalink)
ecomonkey
if you were down here i would probably do it, florida native all my life i dont do cold, much less snow, only saw the stuff twice in my life.
Old 02-08-2010, 10:31 PM   #7 (permalink)
ecomonkey
i did consider bringing them down more Neil, but they would stick out a bit into the air flow but after looking at it,i might put an extra peice below them ,my tires/rims stick out past the body a little down lower.
Old 02-09-2010, 01:11 AM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
moonmonkey -
I'm glad you used the truss strap. I always stare at them but I can't figure out where they could "fit" into my mods. In a way, you could argue that you are doing the "EV1" compromise that also didn't extend the skirt all the way down. Here is their explanation :
Short Skirts?
Short version would likely be that there was a point of dimishing return on the length.
Everything on that car was an issue of weight (each system team received an allocation of weight in grams), aerodynamics, and cost- with the first two very much taking precedent. Folks are right to speculate that for the skirt to have been longer and follow the body of the car, it would have had to curve in, hitting the wheel itself. So to make it longer, it would have had to curve out, increasing the drag and defeating the purpose. Also, the rear wheels were about 7" closer together than the front wheels, giving yet another curve to deal with. At the end of the day, the EV1 was the most aerodynamic production car ever built, with a drag coefficient of .19- when you get that low, squeezing out any more becomes that much more difficult.
Your friend might be interested in reading a fascinating book about the development of the EV1- it's called "The Car that Could", by Michael Schnayerson.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
moonmonkey (02-09-2010)
Old 02-09-2010, 09:37 AM   #9 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Neat looking skirts. Looking forward to the result
Old 02-09-2010, 12:28 PM   #10 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Nice mod, moonmonkey.
That's the only thing I'd be afraid of. Rust from salt on the roads here would be a problem for the cuts, unless they were sealed properly with good 2-part paint, epoxy or something similar.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Interchangable Oil Filters for Echo (or any car) alohaspirit Off-Topic Tech 23 04-04-2010 09:18 PM
echo bellypan install with pics and template moonmonkey Aerodynamics 19 01-26-2010 05:09 AM
echo rear bellypan install pics. moonmonkey Aerodynamics 3 01-17-2010 11:30 PM
echo 1.5 milage camshaft moonmonkey EcoModding Central 8 12-12-2009 10:09 PM
