Old 12-09-2009, 09:46 PM   #1 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
EFI Tuning spreadsheet
I built a tuning spreadsheet that is nice to build fuel maps with.
Spreadsheet Instructions
Line 2
Enter engine Size in Cubic Inches.
Line3
Enter RPM.
Line4
Enter PSI This is how much boost at the intake.
Line5
Enter Elevation PSI. This is found on Sheet 2.
Just add two zeros to the number column on the left.
Example line 8 would be 800’ line 60 would be 6000’
Line6
Enter Intake Air Temperature.
Line7
Enter the size of injector in lbs/hr.
Line8
Enter VE. This depends on the head. Built heads will usually have 1.0 or 100%
Stock can vary from .85 to .90
Line9
Enter how many cylinders.
Line10
Enter air fuel ratio. This should be known by the use of a W/B.
Line11
Enter Brake Specific Fuel Consumption.
This will vary on the type of engine and how efficient it is with its fuel.
Also rich air fuel ratios will have a higher numeric value.
Example: 10.5 A/F on a D16 will be around .55BSFC 12.8 A/F would be around
.50 BSFC
Line12
Enter vehicle weight.
Line13
Enter the original pulse width or duty cycle that needs to be change to target
pulse width or duty cycle.
Line14
This is what you want you’re A/F ratio to be.
Line15
This is what your actual A/F ratio is seen by using a W/B.
Line16
This is what you would change your pulse width to or duty cycle.
On the right side there is Liters conversion to cubic inches.
CC/MIN is to convert cc/min injectors to lbs/hr.
Under the “I9” column is where you can tell what the equivalent injector would be by
adjusting the fuel pressure.
CFM in is the CFM of the engine.
Lbs/min in is what the engine is flowing in lbs. I use this for turbo lbs/min flow also.
M/S MAX in is the maximum amount of time available the injectors can stay
open in milliseconds before the next cycle.
Duty cycle is what the duty cycle is with the inputs you entered.
P/W is the pulse width that the injector will be open to achieve the A/F ratio that you entered.
Hp at the flywheel.
To determine WHP you can calculate on a know drive train in % WHP
Torque is torque at the fly wheel.
W/torque whp torque
E.T. is a approximate time this vehicle at this weight and HP would run in the ¼
MPH is a approximate mile per hour this vehicle would run in the ¼
I recommend you just start entering your own cars values and make changes to see what happens.
This will teach you a ton about what each change does to the engine and its output.
Keep in mind this is just another tool for tuning. I always recommend running a W/B and start out on the rich side.
Can be uploaded below on post #9
Its also nice to just use for the what if factor.
Example:
If I have a 4 cylinder and I'm running 240cc/min injectors what would be the pulse width and how many lbs/min would each injector flow at 4500rpm, 0" of inHg, at 90*F IAT running at 500' above sea level running a 15.0 A/F ratio.
And what would would the pulse width be if everything stayed the same but I riching it up to a 14.7 A/F ratio.
And what would it be if i was running 3500rpm instead of 4500rpm.
etc etc...
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
Christ (12-09-2009), theycallmeebryan (12-10-2009)
Old 12-09-2009, 11:06 PM   #2 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
I'd like a copy to play with.
theycallmeebryan@yahoo.com
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 12-09-2009, 11:55 PM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Hell, if you're just giving 'em away, I got a folder it'll fit in!
Old 12-10-2009, 12:19 AM   #4 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
theycallmeebryan
Christ
You have mail
Old 12-10-2009, 12:27 AM   #5 (permalink)
Indeed I do. I should have left you an email addy, LOL. My Bad.
Old 12-10-2009, 12:40 AM   #6 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Example:
Also it will tell you if you are running an pulse width of 3.0ms with a A/F ratio of say 13.5 but you want a A/f ratio of 14.7 it will show what the new pulse width for the desired 14.7 A/F ratio.
Plus it gives cfm and air lbs/min on theoretical values.
Let me know if you guys have any questions.
I have to give credit to Ben Strader of EFI 101 University.
Its his math that he got over the years from all the OEM MAP based EFI systems. I just put it in a xls spreadsheet so I get the info fast for tuning purposes.
I use it all the time for figuring out different scenarios.
I also made an mpg one base that I need to do some tweaking on before I release it.
Old 12-10-2009, 12:44 AM   #7 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Christ is there a way to put this on the forum so people can get it with out me emailing it???
When I did this on a well known Honda forum I ended up sending out over a 150 emails. LOL
Old 12-10-2009, 01:36 AM   #8 (permalink)
See if you can upload the file as an attachment. You could probably change the extension of the filename to .jpg and if it's under 127k, it will still upload. You'll have to leave a note to change the file extension back to whatever it is, though.
Also, you could upload it to something like rapidshare, then leave the link here.
Or, you could talk to Darin about hosting it.
Old 12-10-2009, 02:09 AM   #9 (permalink)
It worked, I just opened it from the site.
The Following User Says Thank You to Christ For This Useful Post:
pgfpro (12-10-2009)
Old 12-24-2009, 10:43 AM   #10 (permalink)
please fwd copy o brendanobrodie@hotmail.com or slyb28@yahoo.com
Experimenting with tuning leaner and ignition timing. Trike EcoModding Central 3 10-16-2009 12:22 PM
where can I find a coast-down spreadsheet? pstrbrc Aerodynamics 3 10-05-2009 05:44 AM
Spreadsheet for tracking all kinds of mileage stuff! kstruve General Efficiency Discussion 5 06-28-2009 02:34 PM
FI Tuning The Atomic Ass Motorcycles / Scooters 2 01-31-2009 07:13 PM
Just confirming - warmer air on EFI SirKeats General Efficiency Discussion 3 05-28-2008 08:32 PM
