05-20-2018, 07:36 PM
#11 (permalink)
I was at the local tractor, farm implement and vehicle auction. Electric side by side utility vehicles and golf carts are affordable.
05-21-2018, 04:58 PM
#12 (permalink)
Used electric golf carts can be inexpensive to dirt cheap. A lift kit, some tires with better tread and a new set of batteries and you're in business.
My dad has a Menards gasser utv and an electric golf cart. Claims the golf cart takes more work due to keeping the corrosion off of the batteries, cables, etc.
Check Craig's list. I bet you can score a decent golf cart in the next two weeks.
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
05-21-2018, 06:15 PM
#13 (permalink)
I would be looking at places over 100 miles away because there is nothing around here.
05-22-2018, 04:54 PM
#14 (permalink)
Most of these electric vehicles use 36 volt lead acid.
Are there any 36v solar charge controllers or or power inverters out there for 36v?
I know there are endless supplies of 36v plug in chargers since forklifts and floor scrubbers use 36v.
05-22-2018, 05:47 PM
#15 (permalink)
How much is a good quality electric atv?
If you dont need 4wd, wouldn't a cheapie EV do the job well?
05-22-2018, 06:16 PM
#16 (permalink)
Yeah I'm thinking more along the lines of a golf cart or side by side, doesn't have to be 4x4.
05-24-2018, 12:18 PM
#18 (permalink)
I kind of want a golf cart because it comes equipped with its own shade and I could stick some panels on it and a charge controller and probably never need to plug it in. It would likely be able to charge for 2 or 3 days between uses.
