04-21-2017, 02:36 PM
#11 (permalink)
Cps = camshaft position sensor?
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011 + 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
04-21-2017, 03:11 PM
#12 (permalink)
aero guerrilla
Alex, I also have a commonrail turbodiesel in my Peugeot 307, and I cut not the cam, but the crankshaft sensor. I seem to remember that cutting the signal from the cam sensor would not kill the engine, or would add some other unneeded complications, and that is why I had to try my luck with the crankshaft sensor.
In the case of my HDi, cutting the crankshaft position sensor kills the engine without reseting the ECU, but I do get a message about oil pressure being too low.
It logs an error code, but the engine can still be bump- or key-started. The error code can later be deleted with an OBD tool.
04-21-2017, 03:31 PM
#13 (permalink)
Sorry, yes crank position sensor.
04-21-2017, 03:34 PM
#14 (permalink)
Sorry, I wasn't clear on the first post, I did the crank position sensor too. You are right, on mine the car would still run with the CPS disconnected.
I get no warnings, but Mercedes are odd in that they don't have low oil pressure lights or sensors for that matter.
Like yours I can bumpstart or restart with the newly installed starter button. Seems like a good solution.
04-22-2017, 02:43 PM
#15 (permalink)
Did 51.1mpg trip average over 32miles with a 12mph average (central london)today utilising P&G where possible, and stopping engine at traffic lights.
Seems to be a winner!
04-22-2017, 03:43 PM
#16 (permalink)
I also have an MB but an 2003 automatic (w163 ml350).
Would adding a kill switch benefit it at all? Or is it just asking for trouble and entering a world of pain (à la Lebowsky)?
04-22-2017, 03:47 PM
#17 (permalink)
You could use it, BUT, you will not be able to restart without putting the car pack into park, as the starter lockout from the gearbox will prevent it.
I haven't read how the automatics deal with it with stop/start fitted from the factory, but I believe they decouple the gearbox internally at stop.
04-23-2017, 05:59 AM
#18 (permalink)
Automatics also start in neutral. But it is still a problem. No bump starting... and i doubt that i can switch it back to drive and try to get it to start again.
04-23-2017, 03:52 PM
#19 (permalink)
I am examining my torque app values, and at idle, if i have the engine in gear (automatic transmission) then FC is 44 cc/min but if I switch to neutral it becomes 38 cc/min. I can coast in neutral, but if i were to completely shut off the injectors, that would amount to quite some savings.
04-24-2017, 11:36 AM
#20 (permalink)
Final install pics:
