Old 10-25-2022, 07:30 PM   #1 (permalink)
EcoModding Beginner
WJ - '03 Jeep Grand Cherokee Laredo
Team E85
90 day: 17.28 mpg (US)
ZJ - '94 Jeep Grand Cherokee Laredo
Lowering Idle Fuel Consumption
In my 2003 Jeep Grand Cherokee with the 4.0L, according to DashCommand, I’m using 1.2gph at idle with the A/C on (it’s about 0.9-1 with A/C and all accessories turned off). This just seems too high, meaning I would be able to idle for only 16 hours on a full tank. Does anyone have ideas to lower idle fuel consumption or find the culprits? (I run E85, but gph seems to be about the same on 87 octane).
Old 10-25-2022, 09:09 PM   #2 (permalink)
90 day: 40.51 mpg (US)
During my time with Aerocivic, that small Honda D15 idled around 0.10-0.12gph. Part of this was due to a very low idle speed - around 550rpm. E85 does have 30% less energy content per unit volume, so you an expect to use ~43% more fuel under the same conditions. I assume you have a proper E85 tune?
I've also found OBD-based fuel economy instrumentation to be notoriously unreliable. They make a lot of assumptions, giving you the GPH based on displacement, RPM, load, and predicted air fuel ratio. There's a very good chance it idles using less fuel than is being reported, because it doesn't take into account fuel trims, air fuel ratio, or any number of other factors. You simply won't know, unless you can pull data on the injector pulse length, or use instrumentation like an MPGuino.
FlashStopFall (10-26-2022)
Old 10-26-2022, 09:23 AM   #3 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
That does seem quite high, what engine speed is this at?
You might check to be sure your battery and alternator are working properly. My guess is the 4.0 i6 can idle pretty low if you can get the computer to allow it.
The Following User Says Thank You to ksa8907 For This Useful Post:
Old 10-26-2022, 10:43 AM   #4 (permalink)
EcoModding Beginner
Team E85
It idles at 750, and is properly tuned for E85. I didn’t know that about OBDII scanners, I’ll have to get an MPGuino. I can’t seem to find where it’s sold, could you point me toward a kit/built unit? Are there any worthy alternatives?
I’ll pull the serpentine belt off and run it for a minute to see how it affects idle consumption. Thanks guys.
Old 10-26-2022, 02:58 PM   #5 (permalink)
The original MPGuino design needs to be fully assembled from scratch. It isn't too hard to put one together, but it's not exactly compact or elegant.
There's a guy in Australia that sells a color touchscreen version though frankly I slightly prefer the basic one for its simplicity. The touchscreen one is pretty good though, and has features the basic one doesn't.
https://glengineer.com.au/mpguino.htm
Old 10-26-2022, 03:05 PM   #6 (permalink)
1.2gph sounds extremely wrong, that's far higher than my V8 Vantage's cold idle.
The Following User Says Thank You to serialk11r For This Useful Post:
FlashStopFall (10-27-2022)
Old 10-27-2022, 02:11 AM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Keep in mind that there's a limitation regarding instrumentation that directly measures fuel injection pulses to get fuel consumption data.
They absolutely depend on the assumption that there are no variations in the differential pressure between the fuel rail and the intake manifold. With the vast majority of cars, this is a valid assumption. Late model Chrysler products, tho? Not so much.
Most cars either have a fuel pressure regulator that is modulated by intake manifold vacuum, or their engine computers perform fuel pressure adjustments by varying the fuel pump. In either case, the fuel pressure is varyed such that there's always a constant pressure differential between the fuel rail and the intake manifold, typically 43.5 psig.
Late model Chrysler engine computers estimate the pressure differential between the fuel rail that is fixed to a constant pressure at the tank-mounted fuel regulator, and the varying pressure in the intake manifold. The computers then adjust the injector pulse widths by that estimation. It's elegant for the car, but it will absolutely throw off any fuel consumption calculations unless you know how to compensate.
My MPGuino code can do this compensation, and I ran it for many years on my Dodge Magnum.
The Following 2 Users Say Thank You to t vago For This Useful Post:
Ecky (10-27-2022), FlashStopFall (10-28-2022)
Old 11-23-2022, 01:40 PM   #8 (permalink)
EcoModding Beginner
Team E85
Gotcha! I'm thinking of attaching a fuel rail pressure sensor to the bleed port, so I can monitor the pressure and eventually add it to my fuel calculations.
Old 11-25-2022, 12:13 AM   #9 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
did you check your maf signal and it's sensor temp? usually it's because the temp sensor failed and the car thinks it's -20 outside. by math since my 4.7 uses 0.55gph at idle at 600, i would think an e85 4.0 and 750 would use around 0.8ish on e85. check all of your sensors. one of these has to be wrong. the quickest way is to sniff the tail pipe with a wideband and see if it's rich.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 11-25-2022, 04:21 PM   #10 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
I wish I could figure out how much fuel my car uses when idling
ecu tuning, engine mods, idle, idle fuel consumption, jeep
