06-16-2017, 11:45 AM
#661 (permalink)
Primer is still paint!
The Following User Says Thank You to ChopStix For This Useful Post:
06-16-2017, 06:37 PM
#662 (permalink)
06-19-2017, 03:51 PM
#664 (permalink)
Kyle.DRIVES youtube channel
Is a nother good sorce to help understand what is causing the air to move like it is.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
06-23-2017, 04:55 AM
#665 (permalink)
https://youtu.be/_NPNiyR5cWo
MAN 's Concept S Vs curent production side by side cfd
Theres a nice cfd of a tear drop in ground effectat 1:01 and morphing into there bullet truck. at 1:07 .
Former
87' Hyundai Excel
06-25-2017, 03:19 AM
#666 (permalink)
06-30-2017, 12:02 PM
#667 (permalink)
F-35
As compression ceases along the aircraft,the air behaves as any refrigerant,expanding,losing the heat of compression,falling below dew point to create the cloud as the water vapor condenses.
The same occurs inside the aircraft,as some air from the compressor section of the engine,as a working fluid, is run through an expansion valve,creating air conditioning for the pilot.
06-30-2017, 12:22 PM
#668 (permalink)
...beats walking...
...that's also why such 'visible' effects only happen when RH% is high and temperatures are low to moderate...they don't appear under hot & dry conditions.
The Following User Says Thank You to gone-ot For This Useful Post:
07-01-2017, 01:21 AM
#669 (permalink)
Those pic's were taken by my active duty friend while in Germany. They had the F35 at an airshow. Between the wingtip vortices and the clouding effect they are really cool pic's.
07-01-2017, 12:32 PM
#670 (permalink)
It's interesting how the single phenomenon causes two different effects.
The blunt trauma of the bow wave[s] is circular, even though the cross-section of the aerobody is anything but, and dissipates immediately; while the wingtips induce vortexes that persist indefinitely.
