Old 10-19-2010, 12:27 PM   #271 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
BTW if you just think I am lying then VACATE this conversation you serve no purpose being here.
IF you think I tested wrong THEN PROVIDE INSTRUCTIONS for what you would consider "acceptable" testing.
ie how to MEASURE my fuel economy and provide the results to you. I will gladly drive back up to Allentown and bring home MORE E0 to test if you desire.
heck I am even inquiring about using a racing track for a day to have a more controlled test environment. that could cost me more than $100 but I am willing if it will get me good test results.
Old 10-19-2010, 12:49 PM   #272 (permalink)
You would think ecomodders would try to take advantage of the benefits of ethanol.
Old 10-19-2010, 12:54 PM   #273 (permalink)
I agree. Instead of trying to prove why you get so much less mileage with E10. Why not work on improving your mileage with E10? Its not going away, and the government is currently considering switching to E15.
Old 10-19-2010, 02:03 PM   #274 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I think we can reasonably assume this bloke knows what he's talking about :
30% FE detriment in flexfuel engines because of the ethanol.
And that is in engines built or specially adapted to run on ethanol / E85.
The hit when running E10 will of course be lower as there is less ethanol and more regular fuel.
But on an old engine that was never intended to run on ethanol-mixtures, built without the modern electronic wizardry that controls combustion, the hit could well be larger than the expected 30% x 10 / 85 .
The Following User Says Thank You to euromodder For This Useful Post:
rmay635703 (10-19-2010)
Old 10-19-2010, 02:05 PM   #275 (permalink)
1991 RED Metro 1.0 Auto - '91 Geo Metro Lsi Auto
90 day: 38.28 mpg (US)
1991 3/5 2 door Blue/green - '91 Geo Metro
Last 3: 42.6 mpg (US)
Originally Posted by Old Mechanic View Post
Ethanol, once the transition was complete virtually eliminated fuel filter replacement here.
This is BS, ethanol doesn't cause as many problems on newer cars because they have plastic fuel tanks and the rubber in the fuel system is alcohol "resistant".
If you have an older car though ethanol's affinity for water will cause you never ending headaches due to rust in your gas tank and the slow disintegration of the rubber parts in the fuel system.
The Following User Says Thank You to robertwb70 For This Useful Post:
Nerys (10-19-2010)
Old 10-19-2010, 02:18 PM   #276 (permalink)
Flexfuel means the engine is compromised to run on anything between 87 octane regular unleaded and E85. There are no mechanical differences between a flex fuel engine and a gasoline engine. They both run the same low compression ratio and conservative spark timing to protect the engine when its burning on low octane gasoline. An engine mechanically adapted around E85 will be much more efficient as the video demonstrates.
Any engine sold in the US in the last 25 year will definitely have an O2 sensor and probably a knock sensor. Even my old 92 mercedes says in the owner's manual that it is adapted to run on anything up to E10. I've driven in and out of states that require E10 for years and the biggest FE difference that I could measure was maybe 3% at most. If the difference is any bigger chances are the O2 sensor is fried or the owner has been ignoring regular maintenance.
EDIT:
Here's the EPA's proposed E15 warning label for prevent any confusion.
I would like to see the octane rating on this stuff.
Old 10-19-2010, 02:38 PM   #277 (permalink)
VX Padawan
VX du Slog - '94 Honda Civic VX
Just a small observation... I know there has been much talk in this thread about how ethanol contains less energy than gasoline on a pound for pound basis. Ths is absolutely true. However, I think the point is moot, as we are talking about engines that are not 100% efficient. The energy basis is known, and a 100% efficient gasolie engine will yield more power than a 100% efficient ethanol engine given the same amount of fuel.
But when the efficientcy of the engine is a variable, the fact that ethanol contains fewer BTUs than gasoline becomes irrelevant.
It is my opinion that this fact does not support nor deny any argument provided here, it just may help us avoid a red herring.
The Following 2 Users Say Thank You to slogfilet For This Useful Post:
rmay635703 (10-19-2010), tjts1 (10-19-2010)
Old 10-19-2010, 02:50 PM   #278 (permalink)
Grrr :-)
Nerys's Avatar
So they put ALLL that effort into just bringing the engine almost equal than regular fuels.
when if they would simply STOP using ethanol they could already GET that performance without spending a penny?
Part of ecomodding is saving money. You can't save money if you have to redesign/rebuild/rebuy just to compensate for what is a "bad fuel"
at least no one has yet shown me it is anything but a bad fuel. it pollutes more it costs more it uses more it increases dependency. all of these are ecomodding NONO's
NO by the wording I am getting this is likely propoganda or total BS but I sent a message to Poet the people pushing ethanol here in the US.
they tell me they have data showing IMPROVED fuel economy on "unimproved" gasoline engine vehicles on E30. that is chemically impossible to the best of my knowledge.
BUT they claim its possible its bad gasoline causing my problem (I note I drove out to texas no improvement on E10 out to Colorado No improvement on E10 but those were one off trips so anythings possible)
they say some gas companies use really low quality gas and depend on the Ethanol to boost the octane or have bad storage ie water contamination and that this could be causing my fuel economy problems.
this makes sense to a point but is countered by why is it consistent? if it was bad gas or bad storage I should see a dramatic swing in results as I went from place to place or brand to brand. I don't but its still a valid consideration.
Ie there a way to test for water content? is there a way to test for bad gas?
Old 10-19-2010, 02:52 PM   #279 (permalink)
Grrr :-)
Nerys's Avatar
You sort of got it but the wrong way :-)
while the engine is not 100% efficient it is "x" % efficient.
lets say its 20%
20% of X energy (gasoline) is still larger than 20% of Y energy (ethanol)
there is no logical reason for the mechanical efficiency of the actual engine itself to change unless it is not compatible with the fuel (less efficient) or TUNED for the ethanol (more efficient)
but if the engine remains unchanged then its efficiency remains unchanged except for that compatibility issue if present.
Old 10-19-2010, 02:56 PM   #280 (permalink)
VX Padawan
lets say its 20%
I don't think we can make the assumption that a given engine has the same X% efficiency for different fuels. Efficiency is not an inherent property of an engine, but also of its fuel and other environmental variables.
The Following User Says Thank You to slogfilet For This Useful Post:
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 175 08-16-2012 08:32 AM
The Ethanol Scam: Are ethanol advocates giving slanted mpg numbers? Ptero Fossil Fuel Free 15 04-22-2010 09:58 AM
The Ethanol Bubble Pops in Iowa hypermiler01 Fossil Fuel Free 13 04-18-2010 02:19 AM
Ethanol blends: 10% in "reg." gasoline, 5% in mid-grade, 0% in premium (in Ontario) MetroMPG General Efficiency Discussion 40 03-26-2010 09:27 AM
Ethanol in gasoline i_am_socket EcoModding Central 83 12-18-2008 09:01 PM
