11-25-2012, 03:40 PM
#11 (permalink)
Two of the tires I have the most experience with scored well. Conti CH95 and Mich MXV4energy. I couldn't find the Bridgestone RE092.
11-25-2012, 05:34 PM
#12 (permalink)
I compiled the top 5 tires in each size (by my count):
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following 6 Users Say Thank You to Diesel_Dave For This Useful Post:
11-26-2012, 08:59 AM
#13 (permalink)
A Load Index of 118/121 is what is generally associated with 3/4 & 1T pickups. Anything less means the pickup is not able to meet its capabilities (though there are those willing to make that trade-off; generally ride quality associated).
11-26-2012, 10:55 AM
#14 (permalink)
Originally Posted by WD40
I converted it to excel if anyone can find a place to host it, I will post it
I would post is as a public file on Google Docs.
11-26-2012, 12:34 PM
#15 (permalink)
EcoMod Proof of Concept
Thanks MetroMPG ,
My OP link changed, and posted here as well
2000 Insight MT 106K Citrus A/C
The Following User Says Thank You to WD40 For This Useful Post:
11-26-2012, 12:59 PM
#16 (permalink)
I'm a little confused by things now. I was all excited by #385 (Bridgestone Dueler Alenza HL P265/70R17) which has a RRC of 6.2. Then I saw what appears to be the same tire as #149 with a RRC of 9.54. As far as I can tell the only difference is that #385 is listed as OE market (original equiptment), whereas #149 is the REP market (replacement). #385 also was reported by Bridgestone itself, whereas #149 comes from "CEC-B".
Seems like a huge difference for the same tire!
Diesel Dave
11-26-2012, 01:15 PM
#17 (permalink)
Guess what's going on the wish list
Bridgestone B381
11-26-2012, 02:12 PM
#18 (permalink)
Tire Geek
I am hoping you realize that the tires are different. #385 - the OE tire - is the tire as designed to meet some OEM's specs, where #149 - the Replacement market tire - was designed for the replacement market. They are NOT the same tire.
It is common for tires to start out as a Replacement market tire, then a program to supply a tire to an OEM comes along and the tire gets redesigned to the OEM's specs - which are a lot about RR and not much about treadwear. The Replacement tire would be completely replaced by the OE tire.
It is also common for the opposite to happen - OE tire first, then when the OEM no longer wants the tire, the tire gets changed to Replacement standards - which means a better wearing tread compound.
The Following User Says Thank You to CapriRacer For This Useful Post:
11-26-2012, 03:07 PM
#19 (permalink)
So if I want OE tire (#385) is there any way for me to get it?
If I just go looking for a Bridgestone Dueler Alenza HL 265/70R17 tire, will I just automatically get the replacement version (#149)?
Diesel Dave
11-26-2012, 06:55 PM
#20 (permalink)
Tire Geek
So if I want OE tire (#385) is there any way for me to get it?.........
Only if it is still in production. At this point that would be very unlikely.
