View Poll Results: What gauge do you use most
Fuel System Loop Status 1 3.23%
Manifold Absolute Pressure/Boost 1 3.23%
Instant Fuel Economy 24 77.42%
Throttle Position Sensor 10 32.26%
Temperatures 15 48.39%
Average Fuel Economy 23 74.19%
Intake Air Pressure 0 0%
Engine Loading 13 41.94%
Fuel Pressure 1 3.23%
Ignition Timing 2 6.45%
Multiple Choice Poll. Voters: 31. You may not vote on this poll
Old 09-27-2011, 11:57 AM   #21 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
LOAD & IGN
can be used if you are running a different octane and what to see the result or effect.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-27-2011, 06:42 PM   #22 (permalink)
Whitey - '10 Ford Ranger XL
Pickups
90 day: 33.74 mpg (US)
Hershey - '13 Nissan Altima SL
90 day: 28.68 mpg (US)
Midas - '10 Toyota Prius two
Thanks for the input guys. Is my scangauge just not calibrated then? I see 99 LOD very often, so right now when I'm in my pulse phase I try for low 90's. I was reading up on BSFC last night and now I want to try to find the chart for my truck but have had no luck so far.
Check out my facebook page, if you feel like watching my progress.
http://www.facebook.com/pages/MPGran...007268?sk=wall
Old 09-27-2011, 06:44 PM   #23 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z BASE
90 day: 49.05 mpg (US)
For some reason LOD never goes over 84-85 on my car.
Old 09-28-2011, 09:08 AM   #24 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
If you can't find a specific BSFC chart for your car (likely - most of us can't), just use the general ones to get a close approximation. Working from that is something like 95% as good as one specific to your car.
Old 09-28-2011, 06:18 PM   #25 (permalink)
Pickups
Where is the general BSFC map?
Old 09-28-2011, 06:28 PM   #26 (permalink)
CigaR007's Avatar
You can find some here : Brake Specific Fuel Consumption (BSFC) Maps - EcoModder
The Following User Says Thank You to CigaR007 For This Useful Post:
MPGranger (09-28-2011)
Old 09-28-2011, 10:25 PM   #27 (permalink)
Pickups
OK, another stupid question: the islands are labeled with numbers in the hundreds like 370, but my LOD rating only goes to 99, so how do I convert the BSFC number to loading?
Also: If loading is percent of work the engine is presently capable of, how does my scangauge figure out how much work my engine can do?
Old 09-29-2011, 09:44 AM   #28 (permalink)
Hypermiler
Wagons
LOD is roughly tied to the vertical axis on the charts. Find the LOD and RPM combination that's on the top island and try to use that. It's usually somewhere around 2000 rpm and 75% load.
LOD is calculated from the quantity of air flowing through the engine. Only a certain amount of air can pump through a specific engine size, so you can compare what IS going through to what COULD go through. There's a specific ideal ratio of air to fuel for a good burn, so from that you can calculate how much fuel is going through.
Old 09-30-2011, 02:23 PM   #29 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The numbers along the lines indicate fuel consumption - grams per kWh produced - so lower numbers are better.
The vertical line is engine Torque, which relates to engine loading.
Note this BSFC map is used for acceleration only.
Good BSFC doesn't mean best fuel consumption, it just means you're producing the most HP for the fuel being used.
Usually (during constant speed driving) you don't need as much HP, the BSFC is worse, but as you only need very few HP, your fuel consumption is good.
Old 09-30-2011, 04:35 PM   #30 (permalink)
Pickups
So I just need to eyeball the engine loading then?
Also, if I hit 99 LOD with the accelerator half depressed, what happens when I continue to press the pedal?
