Old 08-31-2019, 12:44 PM   #21 (permalink)
wide wake
Originally Posted by lunarhighway View Post
one thing i think to keep in mind when looking at these things is that the dams in themselves are very unaerodynamic shapes, so they will generate a rather wide "wake",
i suppose they don't need to be the full width of the tire to send the air cleanly around it
so when reverse engineering it's best not to assume "bigger is better"
From the upper image you could imagine the tire training within the wake of the spat and on others,that the flow might jump the void of the wheelhouse and then re-attach once beyond it.Goro Tamai did this at MIT for their solar race cars.
Old 09-01-2019, 08:14 AM   #22 (permalink)
Oh Deer - '03 Ford Ranger XL
90 day: 33.97 mpg (US)
Most of the spats I see are on smaller passenger cars that are already fairly low to the ground. Vekke brings up a point about height of the spats making a difference. My question (being I know little about aero stuff) is this.....with shorter spats, is it that the spat covers less of the tire or that the spat is farther away from the ground that makes the difference.
The reason I ask is that I am trying some "reverse mud flaps" on my truck. They are definitely taller than anything I see on Festivas and Prii. But my truck also sits much taller than those. A shorter spat like those from a passenger car (at least in my mind) wouldn't work as well for my application. Or would they?
Is there an optimal "ground clearance" for spats and air dams and such? Or at least a general "rule of thumb"? I seem to remember JRMichler (at least I think it was him) that said he had the best results with an air dam that was 3" above the ground.
If nice guys finish last, are you willing to pay the price to finish first ?
The Following User Says Thank You to hat_man For This Useful Post:
aerohead (09-04-2019)
Old 09-01-2019, 04:26 PM   #23 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Originally Posted by teoman View Post
Also if they produce some noise...
This triggered a thought, the designs we see from manufacturers may be as or more influenced by NVH, than by efficiency. I had thought that many designs seemed to be more about keeping air out of the wheel well than away from the tire. An oversized spat vs none at all could potentially create a similar amount of drag, however the vehicle with an oversized spat would likely have less noise coming from the wheel wells.
Old 09-04-2019, 10:26 AM   #24 (permalink)
rule of thumb
With the variety of vehicle designs I believe that a rule of thumb is impossible.And you might be looking at $50,000 in wind tunnel time to optimize a design for any specific vehicle.
Old 09-07-2019, 12:35 AM   #25 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
This is what I did to touareg. They use similars in big trucks and they work there in windtunnels. So it routes the air to the side of the tire. There are still smalle flaps in normal positions for the air that escapes behind that flap.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 3 Users Say Thank You to Vekke For This Useful Post:
aerohead (09-07-2019), California98Civic (09-15-2019), Gasoline Fumes (09-08-2019)
Old 09-07-2019, 04:48 AM   #26 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Looks very nice and OEM.
Old 09-09-2019, 06:40 AM   #27 (permalink)
Vekke.......that's more what mine will look like. Just not near as polished and OEM looking as yours. Very nice work.
At least mine were cheap. $10 at the pick-n-pull for all 4. I can always get another set someday and cut them shorter and see if it makes much difference. For now I'm leaving them alone.
Old 05-06-2020, 02:40 AM   #28 (permalink)
eagle's Avatar
rozy - '09 Ford Fiesta Zetec S
Too new here and cant post any photos yet, and sorry for the necroposting
yesterday I saw a bluemotion golf tdi upclose, rear spats seem to be a rather plain simple flat straight rectangle while the front are smaller than 1" dont cover the entire width of the tyre , curved, and seem to deflect the air away from the front suspension / front lower arms
so completely different design, I thought they could do more, especially in the back
just my 0.02
Old 05-06-2020, 10:56 AM   #29 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
just my 0.02
They could do more for drag, probably. But there might be a lot of optimization going on in those designs that take into account other priorities, especially brake cooling.
Old 04-11-2021, 10:01 AM   #30 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Most oem cars big factor is can you drive the nose of the car on top of 100mm heigth curb without braking the flaps. That is reason most flaps are just straigth vertical. I will have new design coming for the ID3 flap testing.
The Following User Says Thank You to Vekke For This Useful Post:
freebeard (04-11-2021)
