Old 03-16-2010, 08:58 PM   #11 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
mcrews -
Originally Posted by mcrews View Post
Warning: Increase in size increases wieght. I have been told that the static weight increase, say 8lbs is multiplied by 4 when rolling. This DRAMATICLY increases the demands on the brakes and associated parts like the rotor. So I would start with fresh rotors and pads.
Good luck!!
+1 . When I was doing research on my one-size-up from stock, I considered two-sizes-up from stock. For the tire I was looking at, this is what I saw :
Code:
OEM             = 185/65R15 = 17 lbs.
1-Up from stock = 195/65R15 = 18 lbs. =  5.9% heavier than OEM (my choice)
2-Up from stock = 205/65R15 = 21 lbs. = 23.5% heavier than OEM
CarloSW2
American Solar Energy Society
Old 03-19-2010, 09:27 PM   #12 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
cg did your tire change net a change in fe?
Old 03-19-2010, 10:01 PM   #13 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
moonmonkey -
Yes, a +2% gain :
http://ecomodder.com/forum/showthrea...ires-2642.html
I use the GPS to calibrate the error of my odometer. I add my "2% bonus" in my fuel log. The mistake I made was not doing a GPS check *before* I did my tire change. That would have given me a before/after tire change odometer correction. However, the GPS after-results agreed with my predictions, so I am still happy with it.
In fact, I am way overdue for another GPS odometer check. I will put that on my todo list and report the results soonish.
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
moonmonkey (03-19-2010)
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Largest Tire Diameter on a 6th Gen Civic (for lower RPM) UnCivic EcoModding Central 41 12-07-2009 12:41 PM
Which has lower RR? Large or small diameter tire JackMcCornack General Efficiency Discussion 3 11-19-2009 10:17 AM
tire diameter guitarterry EcoModding Central 56 09-25-2008 01:57 AM
